Question about Kyocera Mita KM-3035 All-In-One Laser Printer
C3200 i cant print exposure lamp ok
  • 36 Answers
Means a defective lamp invertor PCB. Located right under the lamp. Or a bad main board. Or the lamp cable.
I've seen it happen with low voltage also.
Posted on Oct 25, 2007
I have kyocera km1500 and have error A3200 .what is the solution?
Hi
A3200 is not a known error in the service manuals, maybe it's C3200?
Code
C3200
Description
Exposure lamp problem
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Causes
Defective scanner board (KP-5063). Defective exposure lamp or inverter board. Incorrect shading position. Poor contact of the connector terminals.
Jul 24, 2016 | Kyocera Office Equipment & Supplies
E 3200 in kyocera km1500
Code
C3200
Description
Causes
Best Regards
C3200 error
When input value at the time of exposure
lamp illumination does not exceed the
threshold value between 5 s.
Check the connection of connector YC5 on
the ISM PWB and the connector on the
inverter PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Defective exposure
lamp or inverter
PWB.
Replace the exposure lamp or inverter
PWB.
Incorrect shading
position.
Adjust the position of the contact glass
(shading plate). If the problem still occurs,
replace the home position switch.
Defective PWB. Replace the ISM PWB, ISC PWB or CCD
PWB and check for correct operation.
Apr 28, 2014 | Kyocera Mita Office Equipment & Supplies
Error c3200
It means the exposure lamp is not turned on. Either a connector has come loose or the exposure lamp and/or the inverter pwb and/or the control pwb must be replaced
Feb 07, 2014 | Kyocera FS-1118 Printer
My Kyocera km-c 830 shows error code c3200
Exposure Lamp Problem. Exposure lamp does not reach the input value threshold within 5 sec of commencing reading.
Oct 25, 2013 | Kyocera Office Equipment & Supplies
Error code c3200
This means that the exposure lamp is not lighting up or is not being seen.
You will need a technician for this fault unless you can see something obstructing the lamp.
Sep 28, 2013 | Kyocera Mita KM-2050 Printer
Error c3200
C3200 is an exposure lamp problem. The simplest explanation would be a bad exposure lamp or inverter. More exotic, but still possible, is very cold environment, dirty AC power, a bad CCD, or a bad main PCB.
Jan 29, 2013 | Kyocera FS-1118MFP Laser Printer
Kyocera c3200 error Problem
A C3200 is as follows:
Solution:
Replace the scanner board (KP-5063) and check for correct operation
Replace the exposure lamp or inverter board.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
May 02, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Feb 27, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
155 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
