Question about Samsung J700 Cellular Phone
Blue tooth wont pair with anyone/thing
Hi have got a samsung j700, have tried to turn on the bluetooth and says activating and will not pair with any device. If u try to do it again it says bluetooth is already activated but wont do anything else. Please help
  • Anonymous Mar 15, 2014
    how to pair nokia blue tooth device with sumsung s3 gT i9300
  • 181 Answers
Have you put in a code this is usually 1234 or 0000 these codes are put in both units to pair them. the same number has to be put in both devices.
Posted on May 24, 2009
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Samsung WEP460 Bluetooth Headset
Hi I have a samsung AATH200HBC bluetooth headset that was a gift and I've had it on charge for 24 hrs. Blue light is working but dont seem to be able to get any connection with it. Trying to pair it with...
this works with the Samsung range quite well also but you must get the sequence correct - phone blue tooth active BEFORE you turn on the headset then press and hold the on button until the blue light stays solid blue.
Jan 15, 2011 | Eforcity Samsung Bluetooth Headset WEP200...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
My Bluetooth on my j700 wont turn on. help me to fix it
I'm sorry to tell you this, but the fact is that, most Samsung phones are having blue-tooth problems. Some times it might work and other times it might not work. Blue-tooth on most Samsung phones don't work at all and yet they claim to have blue-tooth.
I am saying this out of experience and you can ask other Samsung users confirm this.
I have come across a lot of Samsung phones with this problem, but the fault is from the maker (Samsung) of the phone.
So, you can adapt to the phone like that, or go for another product like Nokia that has an efficient blue-tooth,
Take care.
Sep 22, 2010 | Cell Phones
How do i work bluetooth on a samsung n150
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 25, 2010 | Samsung SCH-n150
I want to connect blue tooth headset with samsung j700 but i dont know how to
hello,put on the bluetooth settings on your phone and also that of the bluetooth headset,after that is done,you then go to your bluetooth settings on your phone to pair both the bluetooth headset and the phone together,when that is done you will be asked to enter a code which is 0000.
after that is done your phone will work as perfect as supposed.
take care.
Aug 13, 2010 | Samsung J700 Cellular Phone
Bluetooth wont switch on
try to look at the bluetooth menu if it's visibility is ON. if not. you should turn it on so the other pairing devices can read your bluetooth..
Aug 30, 2009 | Samsung J700 Cellular Phone
Bluetooth trouble !!
Go to settings-bluetooth-on. Then go back-search device-then wait for it to come on. If you know your bluetooth name look for it. Or you could press and hold the button on your bluetooth while you have your phone searching for the device, it should come up on your phone.
Dec 30, 2008 | Samsung J700 Cellular Phone
Bluetooth help
turn on bluetooth in both the phones
in anyone of the phone try searching for new devices.
it may ask some code for pairing of both the devices.
after giving the code ,both the phones ll be enabled to send and receive the files in both o them..
Jun 16, 2008 | Cell Phones
Samsung J700 Cellular Phone Logo
423 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
