Question about XFX NVIDIA GeForce 8600 Graphics Card
Cant boot up compy with new graphics card to reinstall drivers
When installing the drivers off the CD I was notified that newer drivers were available,. I used windows device manager and now I cant see anything if I turn on the comp with the new card installed. I cant install any drivers without the new card in.
  • mechatamavii May 24, 2009
    Heirin lies a problem. Without the new card in the drivers wont install. Theres only one PCIe slot so I can only use one card, the on board video might work but how do i activate it?
  • 85 Answers
If you have an older graphic card swap it out with the new or if u have onboard video use it as your video. Once you boot up uninstall the nvidia drivers and turn off pc. Now reinstall the new card and install the drivers from the CD or the new ones from the nvidia site. Dont use the windows device manager.
Posted on May 24, 2009
  • Marcos Anguiano
    Marcos Anguiano May 24, 2009
    remove the pci express card and plug it via the onboard video
I have installed a Geforce 210 pcie card on my pc. After I install ubuntu 16.4.1 I get a blank screen with a red box in upper left corner. cant do anything else. Works fine with my older card
Download and burn recovery cd that boots into memory and not install.from here
https://www.system-rescue-cd.org/Download
when booted from it try finding correct video driver for Ubuntu or un install video driver and reboot
Nov 30, 2016 | Computers & Internet
PNY GeForce GT 630 drivers are preventing windows vista from starting
Check the software for the new part, is it compatible with your version of Windows, I think that is the likely problem.
Apr 25, 2017 | PNY Computers & Internet
I downloaded a game and told me that my graphic card needs to be updatedm, how do i update it?
Depending on the exact text of the message, you need to either update the drivers, or you need a newer graphics card. To update the drivers, go to the graphics card manufacturer's website and download/install the latest driver.If the graphics card itself needs to be replaced, you will need to purchase a new graphics card (check the game requirements for the type/make/model card that will work), then install it to your computer. If you already have a graphics card, it's merely a matter of replacing it with the new one and installing the drivers/software that came with it. If it's built in to the motherboard, you will need to install the graphics card, install drivers, then disable the onboard in the bios (check your computer documentation for how to access the bios, typically it will be holding the del key when you see the pc manufacturer's splash screen on boot). If you don't want to get that in depth, most computer stores will do the installation/configuration for you if you purchase the graphics card from them.
Mar 05, 2011 | Computers & Internet
Will not recognise the card although I know it
you need to uninstall the device and drivers-then install new driver first then install the card and be sure it is seated properly
Mar 26, 2010 | ATI FireMV 2400, (128 MB) PCI Graphic Card
Sapphire HD 2600 XT Driver Problems
Just because you have a new video card with CD drivers does not mean the drivers are the latest. Go to Saffhire directly & download the latest driver software for you're card.
http://www.sapphiretech.com/us/support/drivers.php
Uninstall any older driver software before installing newer. Try not to restart the system between installs.
And update windows before you install the new drivers. You do not need to install WinXP SP3. Unless you want too.
May 15, 2008 | Computers & Internet
Install HD3870 graphic card
Follow these steps:
Uninstall current graphics card drivers. Before you install your new card, you'll need to uninstall your current graphics card's drivers to avoid any potential conflicts. Right-click My Computer and select Properties. Under the Hardware tab, find the button to open the Device Manager. Your graphics card should be listed under the Display Adapter heading. Double-click the name of your graphics card to open a properties window for your current card. Last step: Under the Driver tab, click the Uninstall button.
Remove old card. Turn off your PC and unplug it from the wall. Open the case Make sure you first ground yourself by first touching a metal part of your PC case or by wearing an antistatic wrist strap. (Grounding yourself will prevent you from getting shocked and from unintentionally damaging your PC's components.) If you are replacing a graphics card, you'll need to remove a small screw attached to the back plate prior to taking out the card.
Install new card. It wouldn't hurt to page through your new card's instruction manual at this point. Then, take your new graphics card out of its foil wrapper and slide it into your motherboard's slot. Press down firmly with even force until it is securely in place (your system won't boot up unless the card is in all the way). Screw it into the back plate and close up your case.
Install new drivers. Turn on your PC and install the drivers. Windows XP should automatically recognize the new hardware and walk you through the installation wizard. If Windows doesn't detect the card, click Settings from the Start menu. Open the Control Panel and click Add Hardware. From there, a wizard will help you install the new drivers from the CD that came bundled with your new card. It's a good idea to check the graphic card vendor's Web site for more up-to-date drivers, just in case the vendor has released drivers since manufacturing your card. Once you've downloaded the drivers, simply restart your PC. Now, you're ready to start gaming.
If this doesnt work, then your card is BAD.
Dec 29, 2007 | Computers & Internet
Direct X 3D
When you say "it isn't bootable from the cd", do you mean the cd isn't a bootable cd?, or the computer isn't configured to boot from a cd? If the latter, I suggest obtaining a bootable ME cd, but if the computer isn't configured to boot from a cd, depending on the computer motherboard, you will need to access the bios setup, either by pressing the 'DEL', 'F1', or 'F10' key during boot, then under a section called 'boot' or 'advanced-->peripherals' should be the settings on changing the boot sequence, if it's set to this sequence:- 1........REMOVABLE DEVICE 2........HD 3........CDROM 4........NETWORK (not available on some systems) You will need to change the sequence to:- 1.......CDROM 2.......REMOVAL DEVICE 3.......HD 4.......NETWORK (Not available on some systems) Then press the relevent key to 'save & exit', this will enable you to use an ME bootable cd to re-install ME on a clean hard drive.
Jun 12, 2007 | XFX GeForce FX 5700 Graphic Card
I cant work any game using Graphics Card
to see if your graphics card is installed and recognised, go to My computer, right click>properties>hardware tab>device manager, then look down the list for graphics adapter, click on the '+' sign and see if it is recognised, if so uninstall it and reboot pc and it will install itself again. If you require the driver seee this site: http://www.nvidia.com/content/drivers/drivers.asp if there is a yellow '!' mark on the graphics adapter line then right click on it and select update driver and then it should search your system for the driver, assuming you have installed the downloaded driver first, if it is unable to find the driver, choose to manually install and point windowws to where you downloaded the driver, but remember to unzip the driver first if it is in a zip folder.
May 28, 2007 | XFX GeForce MX 4000, (64 MB) Graphic Card
XFX NVIDIA GeForce 8600 Graphics Card Logo
211 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
