Can't open JPEG files loaded from digital camera (Fuji)
I loaded pictures from my digital camera to my PC & saved them in a folder but accidentally the folder got deleted from my system; i restored the lost pictures using Recuva, some of the restored pictures(JPEG files) are opening with Windows picture & fax viewer and also with Microsoft photo editor, but some pictures are not opening with these programs; whwnever i click on those images, a message "Cannot determine file type" is shown. Please suggest how to open these files so that i can view them.
    Brigadier General:
  • 7,191 Answers
Looks as if these files are permanently damaged & are not likely to open.
Posted on May 24, 2009
After I put a picture on my computer, how do i save a picture in JPEG
Yur camera would take pics in JPG format; if not, in the PC, open the picture witj some editor program and "save as" name file dor JPG extension.
Hope helps.
Feb 06, 2011 | Fuji FinePix A820 Digital Camera
Can't view pics on digital frame using new camera
You need to make sure that the pics are on standard jpeg compression, if not try opening file from your pc using mspaint then save file as jpeg
Dec 30, 2009 | Kodak Easyshare M381 Digital Camera
Can my finepix f10 save files in JPEG?
JPEG is the way your camera saves files.
Nov 25, 2009 | Fuji FinePix F10 Digital Camera
Paint cannot save file windows 2000 proffessional
This fix should allow you to use MS Paint to Open and Save JPG files, and Open and Save GIF files. The quality of the saved GIF with MS Paint may be reduced because of the limited 256-color palette (See here for an explanation and workaround). A better alternative for opening and saving JPG and GIF files would be to download and install a great FREE image viewer called IrfanView (MS Paint is still better for individual pixel editing, so it's good to have both).
If you want to proceed with the MS Paint Fix, you should first do a search on your hard drive to see if you
have the jpegim32.flt and gifimp32.flt filters.
You can find those files here:
http://www3.sympatico.ca/one.human/files/Jpegim32.flt
http://www3.sympatico.ca/one.human/files/Gifimp32.flt
You need to make sure you have both filters in the following folders:
C:\Program Files\Common Files\Microsoft Shared\grphflt
C:\Windows\MsApps\Grphflt
You may already have the JPEG Filter on your system, but only in one location. If that is the case, Copy and Paste it to the other location. Once you have the JPEG Filter in both locations, you may only need to do a simple Registry edit to be able to "Save As" a JPG.
If you already have the JPEG Graphics Filter on your system (and in both locations as stated above), but MS Paint still won't let you "Save As" JPG, you can manually edit the Registry to correct this. It's a simple fix. Go to Start, Run, type REGEDIT, and click OK. Go to this key by clicking the + signs beside the keys (folders):
HKEY_LOCAL_MACHINE\Software\Microsoft\Shared Tools\Graphics Filters\Export\JPEG.
Click on the "JPEG" key (folder) in the left pane, and you'll see a String Value in the right pane with the name "Extensions". Make sure under the "Data" column it shows only "jpg". If it shows "jpg, jpeg", double-click on the "Extensions" string and from the "Value data" field remove "jpeg" so that it only reads "jpg" (without the quotes).
If it worked, this edit allows you to "Save As" JPG. If it didn't work, or if you want to be able to also open and save GIF files, read on.
Or use this reg file to export your files as jpeg
http://www3.sympatico.ca/one.human/files/Filter_JPEG_Export.reg
Jul 29, 2009 | Intel Pentium III, 1.13 GHz...
When i email photo it is too large for receiver to open
Hi I am vortash that's very unusual as most emails will take up to a gig on a download now hot mail ., yahoo .. etc so maybe its the format your trying to send that's the problem .. pictures in BMP bitmap are far larger files than say JPEG or JIF files and most mail servers require Jpeg for photo attachments .. and I do know that some cameras actually load pictures to your computer in Bitmap form .. so you need to change them .. easy enough just save them again but choose Jpeg or Jif compliant and the computer will do the rest .. hope this helps Regards Vortash
Jan 20, 2009 | Fuji FinePix F10 Digital Camera
I can't find the digital camera image files I saved on my PC.
Use the procedure below to search for digital camera image files saved on a PC. 1. In the "Start" menu on the desktop, open "Find" -> "Files or Folders". 2. In the "Names & Locations" window, enter the image file name in the "Named" field. Enter "DSCF" as the file name if you have not renamed the file. If you changed the file name, enter the new file name. 3. In "Look in" select the hard disk and then click the [Find Now] button to begin the search. The files found are listed in the search result. Check the results for the desired files. 4. If the desired files are not in the search results, the image files were not saved. --Saving Image Files-- - Downloading images from FinePixViewer or Exif Viewer: 1. Connect the digital camera to the PC. The "Viewer" window opens and the images are displayed as thumbnails. 2. Click "Select All" in the "Edit" menu. 3. All the images are selected (indicated by a pink frame). With the left-hand mouse button held down, move (drag) the images to the folder in which you want to save them and then release the button (drop). - Saving images from a removable disk: Connect the digital camera to the PC. When the Viewer automatically starts up, click the Close ([X]) button to close the Viewer window. Then open the "My Computer" -> "Removable disk" -> "DCIM" -> "100_FUJI" folder and select "Select All" in the "Edit" menu. Then select "Copy" in the "Edit" menu; open the folder in which you want to save the images, and select "Paste" in the "Edit" menu. All the selected images are copied and saved in the folder. You can also copy the images by selecting the entire "100_FUJI" folder.
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 29, 2005 | Fuji FinePix 1300 Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Computers & Internet Logo
297 people viewed this question
David Payne
David Payne
