Samsung CLP-300N Laser Printer Logo
Posted on May 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer suddenly stuck while starting up
I'm using a Samsung CLP- 300 printer. My printer stuck at start- up.I turned on the printer on, orange light was blinking (as usual) then green light goes steady (as usual) and noises came up (as usual) then suddenly the green light turned red and the noises sounded like stuck sound and silent. Then remain red light. OMG help meeeee!
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on May 24, 2009
Anonymous
Expert
Level 2:
Answers
85
Questions
Helped
28841
Points
215
Eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
My Samsung CLP-300 printer has suddenly stopped working. The red light is on constant. I have noticed the black toner drum seems very hard to remove and when you restart the printer it cycles and stop
Dear
Pl. check the error on smart panel, which is available at program window(Click on START .> ALL PROGRAM > SAMSUNG CLP 300 SERIES > SMART PANEL.) give print comand, it will pop up the erro detail.
Thanks and Happy new year.
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
1helpful
Our Samsung CLP 300 's red light stays on..
Install a smart panel on PC and see the error on the PC screen.
1helpful
Samsung clp-300 Error message is "fuser low heat error"
your printer toner is not installed properly. pls shake the toner & fix again.
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
2answers
Samsung printer clp-300
My CLP 300N part of page doesn't print, I am afraid the imaging unit is bad but it has not been used that much
1helpful
No way to cancel print job
If I have to cancel something I hold down the orange button until the printer is completely silent. If I am desperate I just turn it off. It has always worked for me - not sure if it is the right way to do things or not :)
Samsung CLP-300
Open all the covers and close all of them , See any changes if not remove the toner cartridges and see any paper jam in the tray or else. If nothing works out see any sensor is broken physically and update me.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
