Question about Intel D845GVSR Motherboard
Monitor is only in standby mode. there is no difference when we on the CPU. Keybord is also not detected
Monitor is only in standby mode. there is difference when we on the CPU.
  • purnendukrsi May 24, 2009
    can you give me the capacitor ditails which one is change and which value.
  • Marcos Anguiano
    Marcos Anguiano May 11, 2010
    Can you give more details of your issue and what you want resolved?
  • 78 Answers
Its capacitor is blown.........u need to visit service center
Posted on May 24, 2009
  • ALEX SALVE
    ALEX SALVE May 24, 2009
    its capacitor is blown.........u need to visit service center
When i turn on computet, my cpu,mouse, keybord all hardwear run but my moniter don't show anything. my moniter is always run but in my cpu mistek
are your monitor okey.try with a other monitor if it work your monitor is brooken.if not you have a brooken videocard.
all cabels should allways be seated tight.
Jun 10, 2013 | Computers & Internet
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Hp w1907 monitor does not detect any input and goes into sleep mode. checked wiring and connections -- looks normal. No trouble until today.
try to connect the monitor to another working PC, or to a laptop monitor socket, if it works there... then there is a prblem on you PC display driver or display card inside your PC, try to connect another working monitor to you trouble PC and check if that works.
Dec 07, 2009 | HP w1907 LCD Monitor
My monitor shows "auto detection mode
make sure the video card is securly placed in the pci-e slot
Aug 19, 2009 | Dell E228WFP LCD Monitor
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor light goes blinking it does not display .
ok
open your cpu plate then refix your ram after clean it.
also check keybord num lock is on and off
then when u power up press F8 key then go to enable cga mode.then set in display properteis screen resolution to 1024*768
Jan 19, 2009 | Dell E153FP 15" LCD Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
