posted by mimibear on Oct 20, 2007
When we play DVD's the voices echo,
What can we do to change this?
Thanks Terry
2 Other Users Have The Same Problem
Comment by Guest, posted on May 08, 2008
My RCA RT2380 also has a reverb problem. I have looked for any way to adjust or control the reverb but can't find an answer. It is overpowering in all of the different modes. Does any one know how to lessen it or turn it off. Thanks. Another Terry
Comment by rjenbody, posted on Nov 12, 2007
I have an HT-Q80 and the voices echo on dvd's as well. Music and stuff sounds great, just the voices echo.
Solution #1
posted on Jan 14, 2008
If you have the DVD going through your stereo to produce better sound, you could be getting an echo effect by also having the volume on your TV turned up. So a possible solution if this is the case, is to simply turn the tv volume down so that the only sound you are hearing is coming from the stereo.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 20, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I found that the best way to avoid this problem is to mute the television speakers or, if you can, turn off the speakers. There seems to be a very brief delay between TV and theater speakers, causing what sounds like an echo. hope this helps.
Suggest a new solution for this problem
Post a New problem for Home Theater Systems
Email this problem
Email this problem
This Problem Also Relates To:
Dual DWM-3900 System
Panasonic SC-HT500 System
Panasonic 1250W 5.1-Channel Home Theater System with 5-Disc Upconvert DVD Player - Black
Sony HT-V700DP System
Sony HT-7100DH System
Sony HT-C800DP System
Sony DAV-DX255 System
Can you Help with these Home Theater Systems problems?
Panasonic Home Theater System System
panasonic sa-ht700 burned cd...
it only plays burnt cds that i... Answer This...
Audiovox 150W DVD Home Theater System - STS93...
Audiovox DVD Home Theatre...
The dvd tray will not open Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
