Question about Intel Motherboard
Cmos battery failure even after changing the battery
My pc displays that firmware has detected cmos battery failure even after changing the battery pls
  • 272 Answers
May be the replaced battery is not working too. please try another battery or first make sure, the battery you placed is working ok.
Posted on May 24, 2009
  • pravinexpert Jun 23, 2011
    same problem after changed new 3 and good condition battery, that problem with BIOS. I think , update the BIOS.
What is "the firmware has detected that a CMOS checksum error occurred.Press the Enter key to continue. The firmware has detected that the system date/time has not been set." What is this error.
I assume that you entered the BIOS after replacing the battery and set the date and time? If you cannot get to the BIOS after receiving this message, it usually means that the BIOS has become corrupted, either by failure or by virus. You may be able to reflash it if you can download a bios update from the manufacturer.
Dec 24, 2014 | Computers & Internet
Error is the firmware has detected that a coms battery failure occurred
Hello!
i just want to inform you that CMOS battery failure is not a big deal
you just need to replace CMOS battery from the motherboard
CMOS battery is responsible for date and time management in you PC
also it gives a refrence point in time and space when booting
so if you are a serious programmer you may change it immidiately
and if you are a normal user and you are least bothered with system time and date then
you may keep ignoring this message.
thanks and regards
kindly rate this solution!!
Feb 10, 2011 | Intel D945GCLF Motherboard
Pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Dec 21, 2009 | Intel Computers & Internet
''Firmware has detected cmos battery failure''
CMOS battery in the motherboard much measured .3 volt which is a Lithium coin cell battery.check whether the battery gives the correct measurement (recomend to use branded battery like from sony).
if the measurement is correct then reset your BIOS setting by removing all the jumper in the motherboard for about 60 secs.and place it again and start your pc;set yr BIOS to default setting,
let me know if it comes handy to you
Dec 04, 2009 | Intel Computers & Internet
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
Firmware has detected cmos battery failure even after changing the battery
If you have basic knowledge with electronics or that you know the basic shapes of electronic parts, look for a busted electrolytic capacitor on your mobo...it may look bloated or discolored. It can be found near the coin battery. Ask for an expert electronic technician to replace it. If it is still under warranty, have your mobo replaced with a new one.
If your mobo has its circuitry doing fine, you will need to update your BIOS software. Have someone assist you on this especially those who are computer engineers.
May 24, 2009 | Intel D101GGC Motherboard
Clarification about my foxconn bios checksum error
try to change cmos battery...
or
flash BIOS
download bios from bellow link
and pls refer the manual.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000004
thnaks
if ur problem solve so pls rate me..
bye
Mar 05, 2009 | Foxconn 661FX4MR-ES Motherboard
if you have vista you could do a memory check in the boot options by resarting computer and key f10 boot options, then find memory check witch will display any errors with soloutions.
Dec 12, 2008 | Intel D102GGC2 Motherboard
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Intel Motherboard Logo
641 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
