Printer wont go online - light continually flashing green to yellow...
After printer failed to print document, I noticed the light on the printer, which is usually green when online, is now flashing green to orange to green ... Have turned printer off several times, makes no difference, have disconnected power to printer for a number of minutes, still no change. Prior to attempting to print document today we had experienced some power failures overnight. HELP! I'm tearing my hair out.
  • 1 more comment
  • mabswilson May 24, 2009
    I pushed the paper feed button, but no change. When the machine is online the light between the ON button and the PAPERFEED button is green, but at the moment that light is constantly flashing green then orange then green then orange... Usually when you need to press the paper feed button the light is orange.
  • mabswilson May 25, 2009
    Thanx for your help Prem. I completed all the steps you suggested, but no luck. A printer status message now reads 'The used ink tank is full'. I looked at the user manual on my Printer driver CD and it said that I must take the printer to a Technician to rectify this waste tank problem. As the machine is approx. 6 years old and I am hundreds of kilometres from a Canon dealer, I will retire my trusty Canon i250 and use my alternative printer. Thanx again. mabswilson
  • Jim Scott May 11, 2010
    try pushing paper feed button ??
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on May 24, 2009
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
After every page I print, the green light goes out, and I have to press online to get it to continue printing.
Thats ..paper size mismatch, check the paper size settings of your printer in printer properties is the same as what document or document program is set to under page size of the document you wish to print, if these dont match the printer goes offline so you can put in what it's been told is the right size paper or press online to force it to print regardless...so in your case check paper size in both locations and you should be right, there are other things but 99% of the time..thats ya baby;)
Cheers
Nov 15, 2009 | OKI B4600 Printer
My Canon ip1600 wont print with new ink cartridge.
Visite the support tech and try to find a answer for you probelem:
Sep 09, 2009 | Canon PIXMA iP1600 Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon i860 "printer offline" but light is blinking
Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
Oct 17, 2006 | Canon i860 InkJet Photo Printer
494 people viewed this question
k24674
