Question about Hitachi Televison & Video
I pushed the AVX bottom 3 times. The TV screen went off but the red light on. I realized I didn't pushed the off/on bottom and mistakenly pushed the AVX. I picked up my remote and turned the TV off. Now I can't turn it on. I can hear it clicks but there is no picture and no sound. Please help!
  • sima777 May 25, 2009
    Thanks for your reply. I have done this before and fixed it by playing with remote. But I can't remember how I fixed it. It has to do with AVX bottom on the TV and remote. I am not sure what the AVX bottom does (beside switching the TV to Video1 and Vedio2 and something else), but this happened when I turn my TV off when the AVX bottom switches my TV to something other than TV.
    I couldn’t find my remote, so I pushed the AVX bottom on the TV instead of the off/on bottom on my TV. The screen went blue (Vedeo1), I pushed it again it showed Vedeo2, I pushed it one more time and the screen went black ( looked like it was off). I thought I turned it off. But as I was going to my bed, I noticed the red light next to Off/On bottom was still on. As I was going toward my bed, I found the remote and pushed the Off/on bottom on the remote and the red light turned off as it always does.
    Now try turn it on, the red light comes on for 1 second and it turns its self off and hear the click each time I turn my TV off and on. I am addicted to TV, please help!
  • 744 Answers
Hiii.....
If the power supply is supplying the main board with the correct amount of volts, your controller board or your on off switch panel is malfunctioning and needs to be replaced. If its the whole board your looking at a few hundred unless you can find the same tv with a broken screen and just swap parts.The on/off switch board is cheaper but you have to remove alot of interior parts to access and becomes a hastle.
thank u rate me!!!
Posted on May 24, 2009
  • Prakash Ram
    Prakash Ram May 25, 2009
    hi first of all u should check ur transistor connections.Check your
    Horizontal and vertical output transistors.You should also
    check the horizontal and vertical yoke connections as well as your low
    voltage regulators.... if any of these got damaged u should purchase a
    new one.. but try to purchase with the help of a tv service assistant...
    thank u!!!
    rate me
Red Power Light flashes 3 times
3 blinks 3.3v SOS D Board. This is the fault. That's SOS board has the fault. Check this to know more details.
Jan 07, 2013 | Televison & Video
Reader suddenly went beserk, lots of activity as though I were pushing buttons to change pages, etc. and then it stopped working properly; some part of the screen shows correctly while most of screen is...
separtdifge3,
Probably a charge issue, try this:
1. Connect the reader to the computer for 15 minutes (make sure there is a red steady light)
2. Disconnect the reader and press the reset at the bottom
3. slide the power switch to turn it on
4. If the problem persist you will need to do a hard reset
5. If after a hard reset the issue is not resolve problably you will need to contact sony to get it repaires =(
eBookBoy
http://digialreader.freeforums.org
Jul 01, 2011 | Sony Reader Touch PRS-600
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Tv comes on for a few minutes then goes off
If you take off the front bottom panel of the tv wich is easy. Then you will see 6 tuning knobs at the bottom middle of the tv .the top 6 control contrast for the lights dont mess with those. the bottom 3 are the power to each light.red is bottom left if your screen went blue it makes sense that the red is starting to go but if you turn down the power to it left 1/8 turn it should fix it for awhile .Its easy.
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Power light keeps flashing on and off
What make and moel set do you have? Most sets hav a daignosis code built into the flashing power light.
Feb 03, 2008 | Hitachi 46F500 46" Rear Projection...
Tv stuck on tamper proof
If the TV is the same as the one that my father has, hold the tamper prof button in front the tv, and it flashes like 3-4 times. then the tamper button should be turned off.
Oct 24, 2007 | Televison & Video
TV Problem with shutting off by itself
Mine just did the same thing.  Except for it was green instead of blue.  The service manual states 8 flashes from the light stands for an overvoltage.  After reading the manual for a bit I realized the bottom row of 3 adjuster screws from behind the speaker grill adjust the output for the red, green, and blue colors.  BEFORE OPENING ANY TV OR MONITOR PLEASE KNOW THAT THE VOLTAGE INSIDE CAN KILL YOU EVEN IF UN-PLUGGED so please be careful and only adjust what is mentioned here.  I un-plugged the tv, removed the grill and the board covering the internals, and carefully turned the 3 adjustment screws all the way down.  I then waited about 10 minutes (don't know if this made a difference).  I turned on the tv, turned the channel to an auxilary input (for a black screen), and slowly raised each of the 3 bottom screws one by one up clockwise until i could see a faint green, blue, or red line (depending on the screw), and then turned each one back a hair until the screen was black again.  Only adjust one at a time, the order for colors are blue, green, then red from the left.  I hope this fixes your problems.  Be careful when working inside a tv,  I suggest not using a screw driver to adjust the screws due to the possibility of it slipping and someone getting hurt.
Sep 16, 2007 | Sony KP-51WS500 51" Rear Projection...
TV turns off
That sounds like a power board problem if im not mistaken where your power cord plugs into the tv there is a board it connects to often times if u plug the tv in and it starts itself or turns its self off its the power board that needs to be replaced which btw is not cheap at all
Mar 20, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
