In my system the sound is low i am fixed 5.1 sub woofer intex.
Paritala.yeshwanthkumar@yahoo.com
    Novelist:
  • 99 Answers
So like you mention your problem that you have problem with speaker sound problem so i tell you sir that you better search for a good sound card that could match your cheapset there are now day's different sort's of sound card available in the market depend on your use & need requirement most of them do complain this issue b'cause the sound card which come on the chip set does not support 5.1 channel surround system so better consult to a well known hardware engineer for this computer issue untill then have happy computing & see you soon sir...!
Posted on May 24, 2009
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
Sound
first check the settings of woofer or dvd player (keep in 5.1 mode and RAW)
mail me clearly about the problem,
Nov 07, 2008 | Samsung HT-DS610 System
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
Problem w/shelf system stereo system!!!!!!!!1
You say that the fault lies in the sub-woofer speaker....
You will need to remove the back panel of the speaker box and make a visual examinatiojh of the contents there just may be an overload fuse there that you can replace your self...there may be a broken wire if the Sub-Woofer has been dropped...
There may be a capacitor or choke that has come loose from its mounting and in falling broken a wire,,,but please have a good look to see whats gone wrong inside the sub-woofer cabinet.
If you like you could take the backs of both the right and left
sub-woofer speaker boxes then visually compare the good one with the faulty one so you can see if there is any physical difference on the faulty one...if they both look the same then you willl need to do some testing with a multimeter set to Ohms to see where the break in continuity lies...just compare readings between the good one and the faulty one to find the fault..
Cheers From YUBEUT..
Nov 23, 2007 | Brookstone (400003998814) Shelf System
Connect Issue?
You need to make sure your using cable rated for use as Sub woofer don't use Audio or Digital Cables they're not the same.
Oct 20, 2007 | Samsung HT-DS1000 System
 Grubhead
Grubhead
