Question about Sony Cyber-shot DSC-S730 Digital Camera
Turns off right away
When you press the power button the camera turns on for less than a second, the light comes on and it makes a chirping sound. Then it turns right off.
There is a problem with the zoom lens: it is stuck and sort of titled to the side (i dunno how else to describe it). Turning on the camera doesn't make the zoom lens move.
  • 744 Answers
Hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
rate me!!!
Posted on May 24, 2009
My new Firex 21007581 with a new battery keeps chirping. What is the problem and how do I fix it? Thanks Sal
He said it had a new battery so he already did that and why would you service a $12 throw away smoke alarm? This FIREX he identified is the 4618 and will also chirp while the LED light blinks, chirp is about 30 seconds after blink if the unit itself needs to be replaced because there is something wrong with it as opposed to a different chirp pattern for battieries. If still unerwarrantee FIREX will replace otherwise go buy a new one.
Sep 07, 2011 | Kidde 21007581 120v Firex 4618 Pro Basic...
How is the chirping sound turned off?
1. Open Hood (ground blue hood pin wire if no hood pin switch is installed)
2. Turn Key to the ON position
3. Press program / valet button 5 times, after a few seconds the unit will flash the lights 5 times.
4. Push the valet/program button 18 times. You must get a light flash after each button press.
5. Press the LOCK button to turn chirp confirmation off.
6. Turn Ignition OFF, Close hood (or unground blue hood pin wire) and check for changed features.
Dec 28, 2010 | CrimeStopper SP400
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
Gmc sierra 2008 low tire pressure problem
You can follow this to reset it.
Ignition ON, initiate the TPM Learn Mode
using one of the following procedures:
  1. On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  2. On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  3. Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
    When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
    Ignition OFF, adjust all tires to the recommended pressures
Jan 22, 2009 | 2000 GMC New Sierra 1500
Philips 55PP9352 Rear Projection, no picture or sound
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Won't turn on...
first Trun up the screen, is you see vertical colapse IS because you not ertical Drive..
Jul 26, 2008 | Zenith R50W46 50" Rear Projection...
It doesn't power up
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
283 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
