Question about ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ)
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
I want to hook up a new hard drive, a 500gb sata western digital,need to know how,were like maybe a diagram.
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    You could try connecting the SATA cable between the Hard Drive and the MoBo via the supplied female SATA ports and power from a extra four pin connector from the power supply.
  • 85 Answers
This motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
Posted on May 24, 2009
I have amd 2800+ and asus mother board my system support id harddrive but not supported sata hard drives why
Please download the latest bios driver and upgrades for SATA operation and read the procedure for SATA application, in the Asus home page, write also your MoBo's type.
Hope that helps!
Apr 29, 2012 | AMD Sempron 2800+ CPU with Mother Board...
Hi, cannot find the right set of drivers for the mobo A7N8X Deluxe. It does not recognise my SATA drive, even I've installed corresponding drivers After pressing the F6 key and installing the SCSI Drivers...
Connect your SATA on the first SATA slot to make it as the Master. Or maybe the BIOS settings is set only to recognize IDE device. If this is the case, try going to BIOS settings then Peripheral Devices, look for the menu Hard Drive and replace the IDE into SATA.
Feb 04, 2010 | ASUS A7N8X Motherboard
I have a 320 as my primary and i want 2 ad a 500 sata wd how do i set the pin jumper for secondary on my new one and the factory 320 has no jumper at all thanks
The SATA Drives do not need jumpers to set primary and secondary drive positions. Each sata drive gets it's own connection to the motherboard. Check you motherboard diagram, and make sure the 320GB drive is plugged into the 1st sata controler, and that the 500GB drive is connected to the 2nd.
Oct 11, 2009 | Western Digital Caviar 500GB Internal SATA...
I have an asus a7n8x-la mother board. It ran fine except the cpu cooling fan would speed up and the cpu heat sinc was very warm as compared to others. Finally it would not boot or go to post with the beep....
First of all set the BIOS default.
i think somebody change your Bios settings like-- over clocking or speeding fan etc etc.
add comment for further assistance.
Good Luck!
neo
Feb 27, 2009 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Sata concetion
SATA HDD's do not have master/slave/cs jumpers like IDE drives do because only 1 cable is connected to each drive, so you have to plug whichever HDD you want to be primary into the SATA0 port (or SATA1 if there is no SATA0) on the motherboard.
Also make sure you have your masterboot recrod installed on the drive you use to boot.
Jan 22, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) Logo
521 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
