Question about Zoom X6 (5590) DSL Modem (55900003)
Zoom 5590 modem used on Embarq dsl
Embarq recently changed our area from PPoE to DHCP on DSL. Thats fine but they didnt tell anyone! After being told my old 645 modem would no longer work I went a bought a Zoom 5590 dsl modem/wireless router/switch combo.
Embarq is trying to tell me basically it wont work no mater what - Is this true?
What settings do I need to change to maybe get this to work?
  • 1 more comment
  • dylan_barber May 24, 2009
    I have looked over all the zoom documention and even compared setting on the 660 mdem Embarq sent me to whats on the Zoom
    I refuse to accept that there is no way to make the modem work as per one of the experts here
    Come on resetting the modem and looking over the documentation are not answers - I dont want to **** people off but i some one could give some real settings it would help
  • 432 Answers
Reset router / modem so its at factory defaults ( using a paper clip whilst the router is powered on ) hold the paper clip down on the reset button for a good 5 to 10 seconds.
Give it a few minutes to reset and then try and logon to the routers configuration page using internet explorer or any web browser such as firefox.
The I.P Address of the router should be set to default ( which should be stated on the underside of the router )
For more specific information ( http://www.zoom.com/techsupport/adsl/adsl_x6.shtml ) Am not sure which one you have exactly.
Am guessing it will be one of these ones ( scroll down to see pdf files )
http://www.zoom.com/techsupport/adsl/adsl_5590A-BF.shtml
The quick guide setup and full guides should walk you through this and they are suggesting to ensure all the software is installed first and then going to the web interface so may be an idea to do that ( installing the software first ) then do something along the following
Close all programs including antivirus software and pop-up
blockers.
2 Log into the Zoom Configuration Manager from the
computer on which you installed the X6 software:
a Open your Web browser and, in its address bar, type
http://10.0.0.2 and then press the Enter key on your
keyboard.
On the Enter Network Password dialog box, type the
following user name and password in lowercase then click
OK. (The User Name and Password you enter here are
not the same as the User Name and Password that your
Internet service provider may have given you.)
User Name: admin
Password: zoomadsl
2 After you log in, use the Basic Setup page to configure the
modem so it can connect with your Internet service provider.
Do the following:
a Enter your Protocol, Encapsulation, VPI, and VCI
settings in the appropriate boxes. Your service provider
should supply these values. If you do not know these
settings, refer to the tables starting on page 93.
b NAT (Network Address Translation) is Enabled by
default. This feature lets multiple users access the Internet
sharing a single IP address. Enabled is typically the right
setting. Select Disable in the unlikely event that you want
to assign different public IP addresses to each network
user.
c Depending on the Protocol setting you selected the
bottom half of the page will change so that you can enter
additional information.
If you selected PPPoA or PPPoE, enter your ADSL
Username and Password in the appropriate boxes.
Your Internet service provider should have given this
information to you. (Your Username is typically your
email address or the characters preceding the @ sign
in your email address. This is NOT the same
Username and Password that you used earlier to open
the Zoom Configuration Manager.)
If you selected 1483 Bridged or 1483 Routed, you
have the option of using either dynamic or static IP
addressing. Depending on your situation, select the
appropriate option button:
− [MOST USERS] Ensure that Obtain an IP
address Automatically is selected if you are
using Dynamic Host Configuration Protocol (also
known as DHCP or dynamic IP addressing). This
option is selected by default because most Internet
service providers use DHCP.
− Select Use the following IP Address only if you
are using a static IP address. (You should know if
you are using static IP addressing. There is
typically an extra charge for a static IP address and
you usually have to make special arrangements
with your Internet service provider to get one.)
Then enter the IP Address, Subnet Mask,
Default Gateway, and DNS that you plan to use.
Click the Save Changes button, then click the
Write Settings to Flash button.
Everything is in the manuals on the pages I have posted and is exactly what I would do in terms of following the guides
As you mentioned you were using dhcp so some of the above may be wrong or not relevant as you would most likely select DHCP.
The manuals have screen shots etc so may make it easier
Posted on May 24, 2009
  • 3 more comments
  • Shane Russell
    Shane Russell May 24, 2009
    If none of the manuals and advise given helps then I would suggest getting a refund for this zoom router and getting a DSL linksys router.
    The linksys routers can be configured through the web interface on an ip address of 192.168.0.1 or 192.168.1.1 and have a default username / password and configuration is a lot easier and you do not require the software for them and they are robust.
  • Shane Russell
    If not linksys then at least draytek or netgear
  • Shane Russell
    There is also an apple airport extreme ( which you may just need to buy just a DSL Modem ) and then connect your DSL modem directly to the airport extreme.
    That is what I would do instead of the linksys, netgear or draytek. Yes expensive but well worth it.
    Also before you get rid of this zoom modem you can try and update / upgrade the firmware on it and try it again but make sure when you do the firmware update you are directly connected to it via an ethernet / network cable and NOT and I repeat NOT over the wireless.
    However the only down side with doing this is that it may effect the warranty and may make it more difficult to return it or get it replaced so I would check this with the place of purchase.
    As per above you are better off getting a better make / model of router.
  • Shane Russell
    Also check with your ISP to ensure that the modem / router you get is compatable ( it will most likely be but always worth checking )
    ADSL ( DSL Modem )
    http://www.broadbandbuyer.co.uk/default_...
    Due to being in the USA it will most likely just be a DSL modem which will only have 2 ports ( one for the telephone line and one for connecting to a router like the airport extreme )
    Airport Extreme
    http://www.apple.com/airportextreme/
  • Shane Russell
    http://store.apple.com/us/reviews/MB763L...
    Reviews from numerous people who have rated it with all stars and written a review to state that its been brilliant and easy to configure
    Genius:
  • 1,689 Answers
Look for the reset button, press that for 10 seconds, pull the power out, then after 10 seconds put the power back in. once the power light is stable, let go of the reset button.
    Sergeant:
  • 296 Answers
Hi ,
I completely agree with the previous tech who did mention that all adsl router would work until and unless Embarq uses some other technology.
Matter of fact Embarq does use their own set of cofiguration and it would work only with routers or modems brought via Embarq. Your Zoom product will not work how hard you try to configure it.
Yes, different modems will work when configured with the proper information.
However, Embarq basic support does not support ADSL modems that were not purchased through Embarq or an Embarq sales channel
Source: http://www.dslreports.com/faq/sfc/3._Setup_Installation_and_Configuration
Therefore as per the previous tech and me and Embarq CSR there is no settings on your Zoom that will make it work wit Embarq.
Thanks
    Brigadier General:
  • 3,917 Answers
Well I donot know whats the reason your ISP provider is saying that the new router will not work. Technically all routers / modem work with standard connection . Hope your ISP does not use any technology which is out of this world. To support my statement you might want to visit the following website.
http://www.zoom.com/products/adsl_overview.html
Normally you can find the entire process of hooking your router to the internet ( both via ethernet and wireless ) in he manual which might have come with this kit.
U can login ur ISP u can find. go to browser type your IP address for ex. http://192.152.185.1 and press enter. it ask user and password. u can login ur user id and password of your internet provider. u can find there. default user id and password is admin and admin .
Thank You
I have the Zoom X6 (5590) DSL Modem, trouble using software
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Dec 12, 2009 | Zoom X6 Adsl Modem/router Rohs...
How do you change your modem adress?
Here is the Manual via PDF.. This should help. Its doesn't look like this Modem will allow you to change the mac address. That's usually done in your router.
http://www.zoom.com/documentation/adsl/5590_QuickStart_Eng.pdf
Nov 22, 2009 | Zoom X6 (5590) DSL Modem (55900003)
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Itouch
I TRYED EVERYTHING THEY ARE TELLING ME TO DO BUT WHEN I TURN IT BACK ON IT SAYS ''IPOD IS DISABLED CONNECT TO ITUNES''.
May 03, 2008 | Zoom X6 (5590) DSL Modem (55900003)
DSL light flashing constantly
I had the same problem to begin with. Here is what the Zoom helpdesk suggested:
"To force the dsl light to stop blinking, please follow these steps.
1) Open up your web browser and type 10.0.0.2 in the address bar. Type in the the username and password to log in to the modem.
username: admin
password: zoomadsl
2) When you get to the address bar, Click on advance setup.
3) Click on ADSL Configuration.
4) Change the standard to G.Dmt and change the activate line to Start.
5) Save changes and then write settings to flash.
Within a 1 or 2 minutes, the dsl light should go solid."
This worked for me. Good luck.
Mar 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Wrong ip address
Can you clear your question??? Plz can you tell me which router/modem you r using?
Jan 06, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Configuring ppoe connection with zoom modem
Your external (WAN) IP should be set to DHCP for most ISP's. Your internal IP will be the default gateway for everything in your LAN to get sent to. If you can log into the zoom with your browser, try that IP address for your gateway. If not can you let me know some more details on your zoom model.
Aug 02, 2007 | Zoom (56600000) DSL Modem
Zoom X6 (5590) DSL Modem (55900003) Logo
222 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
