Question about Apple AirPort Extreme Router
Apple AirPort cannot get IP address from cable modem using DHCP
I just switched from DSL to Time Warner cable modem service. I can connect my MacBook Pro directly to the modem and get a valid IP address just fine using DHCP. But when I connect my Apple aiport base station to the modem, I cannot get an IP address from the modem. I can talk to my base station just fine from the MacBook, the problem seems to be between the base station and the modem. I am connecting from the airport to the modem using ethernet, not PPPoE - I did not have to use PPPoE to connect my MacBook to the modem, so I assumed I didn't need it to connect from the airport to the modem. I already called Time Warner about this and they can see my modem talking to the airport. Because I can connect my MacBook directly without a problem, they of course say it is not their problem.... Any suggestions? I have turned the various pieces of equipment off an on about 50 times already - no help....
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    You can power down & up the components 100 times and if not in the correct order no positive results should be expected. If you have powered down the modem, router, and PC then powered up the modem then 20 seconds or more later the router and then the PC and still no luck then you have my sympathy.
  • 600 Answers
Go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
Posted on Aug 13, 2009
2 Suggested Answers
SOURCE: MacBook not connecting to DIR-655 Router
My solution was that I changed the wireless mode from "B,G and N" to just "B and G," and then it worked fine.
Posted on Feb 07, 2009
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Tip
How to obtain public IP from Time Warner
<p>There are two basic types of IP addresses of internet service providers (ISPs) to provide customers with Internet services: a dynamic address or DHCP and a static IP address. A static IP, as the name implies, uses the exact same IP, and you're online all the time. The DHCP IP configuration uses a "stack" of available IP addresses each time a modem is online and an IP address of the network of the ISPs is simply grabs the first available IP address from the stack. The IP configuration of DHCP, then it is very easy for a new public IP address from your provider at any time <br /> <p><br /> <p>1. Unplug the cable modem from Time Warner. Total count of 30 seconds and close. <br /> <p><br /> <p>2. Allow the modem to reboot every five minutes. During this time, goes through the boot cycle, contact your provider and ask for a dynamic IP address. <br /> <p><br /> <p>3. Navigate to the computer's IP Configuration Manager. For most versions of Windows, the easiest way to do this is to open the Start menu, click All Programs, then select "Command Prompt" from the "Accessories" menu (for future versions of Windows, you may need to the right button on the Command Prompt and select Run as Administrator "to show itself sufficient permissions on IP of the computer information). <br /> <p><br /> <p>4. IP address to test your computer by typing "ipconfig" and "Enter" Command to the numbers printed next to "IP address", like "IPv4 or IPv6 address." The number displayed on the public IP address of the DHCP as the modem from Time Warner will receive net. <br />
on Jun 22, 2011 | Computers & Internet
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
I have a wrt310n router and cannot get internet connectivity when trying to configure a wn2000rpt
is your wn2000rpt connected to the wrt310n or the modem? are you using DSL modem? if so you may need to call in DSL service provider to configure something on their side first. for router configuration, you need to use static IP on your computer in the same subnet of the default IP address of your router. did you configure it yet? if you already get in the configuration page, then try to use DHCP only on one router. if you are using DSL modem then you might need to choose PPPoE as the connection type. Then check the cable and reboot your computer. If your computer is configured as receiving DHCP IP address then make sure there is a DHCP on your router. Anyway, if you tell me the details of your modem and router make, model and connection and the operating system on your computer I can tell you more.
Apr 23, 2011 | Computers & Internet
Will not connect to internet completed all connection but cannot connect to internet
Router's have their usual way for them to work with your preferred Cable / DSL Internet Service Provider.
Cable Internet usually requires a MAC clone and power cycle to work properly while DSL Internet often required a username and password that came with your DSL povider.
If you want to configure your D-Link router then try accessing it Web Interface;
This instruction is for Cable modem installation however if you're using DSL modem then just change the WAN connection type to PPPoE and type your user name and password.
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
Step 3 Power cycle the cable modem and router:
  • Turn the cable modem off (first)
  • Turn the router off
  • Leave them off for 2 minutes**
  • Turn the cable modem on (first)
  • Wait until you get a solid cable light on the cable modem
  • Turn the router on
  • Wait 30 seconds
Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address.
Hope this helps!
Oct 15, 2009 | D-Link Computers & Internet
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Can't connect to the internet with my Airport Express
Make sure your network settings are set to DHCP manually and that you are getting an IP address that does NOT start with 169.258
If you are using a Windows PC you may have to use the ipconfig /release and ipconfig /renew to refresh your DHCP settings.
Also try using the Airport utility (located in the Utilities folder) if you have a Mac. It will tell you if there is an issue.
Dec 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Lost Net Connection after iMac was disconnected from Network
Cable modems don't usually have this issue so I'll assume your on a DSL connection, 56K modem, or someother phone related variant. You were most likely setup for a connection through your Airport using local IP settings on each machine and when you moved the machine you reconfigured yourself with a DHCP address. There are two solutions. (1) Reconfigure every machine for DSL (2) Configure your airport for DSL and connect everything to it.
Unfortunately the process from one provider to another varies slightly. But for that reason I generally only recommend cable for multi-computer housholds sharing a web connection.
Dec 21, 2008 | Linksys Wireless-G WRT54G Router
Change ip
Your IP address is assigned (leased) to you from your internet service provider. With that being said, you could possibly call them and ask to release your old IP address and have them assign a new one. If you happen to have a static IP address assigned from your ISP you can call them as well and ask to have your IP address changed too. It would be up to them to change it though.
Sep 14, 2008 | 2wire (1000-400108-001) Router
Apple AirPort Extreme Router Logo
2,226 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
