Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
Hello , My problem is : The hard disc TrekStor TM ( Model No.:DSMMU-S-SU-a ) is since two days default. Sunplus USB2SATA USB Device is athe moment a change hard disc . I ahve no chance to reading my backup files . Do you have a update for this problem ? Thank you very much Mr. Oliver Frank Bachert
  • Oliver Frank Bachert Jun 27, 2009
    The Solution: ... IT WORKS REALLY ...
    Point 1: Remove power from the mains.
    Item 2: The device from your PC, remove the USB plug.
    Point 3: The USB Titanium External Hard Disc Enclosure Open, just the screws of the housing, with a special wrench to open.
    The drive from the connector of the USB connector for one minute to remove, then the hard drive with the connector of the USB connection,
    connect together.
    Point 3: The hard disk into the housing insert all the screws screw.
    PLEASE precisely again check that all connections are properly connected.
    Power to the drive plug the USB connector from the HDD to the PC or notebook is already running and the hard drive, as before, during initial installation of the device.
    So everything supper dooper easy ...
    connect together.
    Brigadier General:
  • 5,158 Answers
Are you getting any warning indicater lights or noises.... and is the drive recognized by the computer ?
Posted on May 24, 2009
Trekstor model dsmmu p a has a clicking sound and data can not be read by computer
The sound you are hearing is known as the click of death. The hard drive is no longer any good.
Feb 12, 2014 | Trekstor Computers & Internet
My tredstor external hard drive dsmmu-p-in-a all of a sudden asks if I wants to merge the files (on my computer hard drive) with the previously saved files on my trekstor (of the same name). It hasn't...
OK hello I'm new to the tech support any way how much memory on the Hard drive and much is left on the external drive it may ask you to merge to tell you you need room for all files and that you may have almost reached the compasity on the drive
Mar 12, 2017 | Trekstor Computers & Internet
Hi there, my TrekStor external HD model
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | Delta & Single Handle Shower Faucet
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Iomega Burner loads as Sunplus Bridge
Hi,I had the same problem,its most likely the upper and lower filters.go to my post run number 11. hope I helped
Please rate my sollution
Jun 01, 2010 | Iomega Super DVD QuikTouch Video Burner...
External hard drive shown as portable disk and does not work
hi
i think the hard drive is ageing,
if you are past warranty try to open up the casing and try to see if you can connect the HDD to connect individually else where (like with another casing or Laptop PC) if still not connecting then the problem is with the HDD
else the problem may be with the casing
cheers
pls rate if this was any help
Jul 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor Storage device
I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
May 03, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Computer does not recognise Hard Drive
Hey guys. I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
Feb 11, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
261 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
