I've just rebuilt my PC using a JW-N61P main board with and AMD athlon 6000 cpu. I have one SATA II drive, a pioneer DVD ROM, and a single floppy. I can boot the PC to BIOS level but can get no further. The PC shuts down when I attempt to save default BIOS settings. The Power supply is an Amcrox 750W true. Any clues as to the reason for the failure? Note that all hardware is recognised at boot up but I cannot get to the point where I can install new drivers. Mark
  • Yellow_Peril May 24, 2009
    I disconnected the floppy and the DVD without success.
    I then used another DDR2 chip and got the same result.
    Could be the motherboard?
  • Yellow_Peril May 26, 2009
    Thanks. No PCI devices installed.
    However I did find the problem. The CPU cooler was faulty resuting in overheating and shutdown. I replaced the cooler and the PC stayed up.
  • 75 Answers
First remove the all dvd rom drive ,floppy drive except hard disk..then try to boot if the problem occurs again then the RAM have some problem..
Posted on May 24, 2009
  • ianswer007
    ianswer007 May 24, 2009
    Have u connected any PCI device ,if yes try to remove them ..and try to boot..if no success then your motherboard is having some problem....
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
How much power do I need for this board?
Power Supply Calculator,
http://extreme.outervision.com/psucalculatorlite.jsp
A) System Type: 1 physical CPU (Processor)
B) Motherboard: High-end desktop (KN1 Extreme)
C) CPU Brand: AMD
4) CPU Socket: Socket 939
5) CPU: Lord only knows. I chose a Processor that uses Up To 89 Watts. AMD Athlon 64 4000+ 2400MHz San Diego 1.35v
6) CPU Utilization TDP: 90% TDP (recommended)
(In otherwords leave alone)
7) Overclock my CPU!: Leave alone
8) RAM: 2 sticks of DDR SDRAM
9) Video Cards;
A) Video Brand: AMD (AMD owns ATI now)
B) Video Card 1: AMD Radeon HD5450
C) Video Card 2, 3, and 4: Leave alone
D) Video Type: Leave alone
E) Physics Processing Units: Leave alone
10) Hard Drives:
A) Regular SATA: 1 HDD
11) Go to Drives;
DVD-RW/DVD+RW Drive: 2 Drives
12) Go back up to the right; PCI Cards:
I left alone. Only you know at present, if you are using one, or more of these types of PCI cards.
13) Go to Fans;
80mm / Regular / 2 Fans. (Just guess-timating)
All fields should be entered now. If not make adjustments to what I didn't know. Include in the proper field.
Now go to the bottom right, and click on - Calculate
(Calculate / Reset / Print )
I come up with 265 Watts.
Want to know EXACTLY what hardware is used inside; without opening the computer case?
Use the tiny free program, CPU-Z from CPUID.com
(Can help you download, install, and use, CPU-Z if you need.
I have used CPU-Z for years)
http://www.cpuid.com/softwares/cpu-z.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | ECS KN1 EXTREME Socket 939/nFroce...
Can I install a none sata ide hard drive in a Asus Cm1630-06
lilpolak
Most motherboards have one IDE port on this that you can run 2 IDE devices off of. Note the main reason for this IDE port is not all ROM drives are SATA yet but you can run hard drives off this port as well.
Let me know if you have any more questions or problems
Issken
http://www.fixya.com/users/issken
Sep 29, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
My cpu ran smoothly for a year now. then all of a sudden, it encounter the bsod. try to reset it and nothing happens. i leave the cpu for about 30 minutes and it boot up. one beep and it freeze to loading...
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Aug 31, 2010 | AMD Computers & Internet
I need to format it as cant get rid of a program
go to boot sequence then change to cd rom then it install & format it
Apr 15, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
Disc wont even load up, disc drive used to work but done a system reboot and now not, tried changing disc drives and that doesnt work.
hi there, it may be that the drivers for your CD/DVD drive may be erased. Go of Acer's website and see if they have your disk drives drivers and install them.
Jan 20, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
No usb ports are working,dvd drive do not burn.
If you are having multiple component issues you should probably check if the motherboard isn't acting up; usually this is the solution to many problems at one time since the motherboard keeps everything running together smoothly.
Check the inside of your CPU for dust and also check your configuration (via My Computer and right clicking on the appropriate drive) of your DVD writer.
Hope this helps!
Dec 27, 2008 | Acer Aspire M1100-U1402A Refurbished AMD...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
