Question about Acer Aspire One PC Notebook
Aspire One won't boot
My Acer Aspire One won't boot. Power light comes on but screen remains black, no action. Worked fine, shut down and now this. Any ideas?
  • 2 more comments
  • michelledism May 24, 2009
    Geekman,
    Negative to all suggestions. Am trying Fougzki's now. Thanks guys
  • michelledism May 26, 2009
    This doesn't seem to help. I had to load the new bios to my FAT formatted USB on my other computer. My Name was E:/hpv125w.
    I had the Flashit.exe and the renamed ZG5lA32.FD there. I moved the USB to the AA1 and followed the directions exactly but nothing happend. I do hear the machind but no reboot. I have repeated this per instruction. What did I mess up?
    Thanks Michelle
  • fougzki May 11, 2010
    Check also your memory card. If you already check it with external monitor if it does not help. Reseat or clean its edge connector with a soft eraser. Do this when unit is off and battery is disconnected and no any other power source is connnected to it.
    And leave a message
  • Chris Hingee
    Chris Hingee May 11, 2010
    Can you hear the hard disk spinning?
    Is there a very dim image on the screen when you view it at a sharp angle?
    Connect an external monitor to the laptop, power up the monitor first and then the laptop, do you see the normal Windows image on the external monitor?
    Get back to me with what you see and any error messages.
    Problem Solver:
  • 32 Answers
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 19, 2010
  • 489 Answers
If you tired to Bios update there is no way to runaway to go to the service because your mainboard is broke down.
Posted on May 27, 2009
  • 7 Answers
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
  • 1 more comment
  • jnversteegh8 May 26, 2009
    Did you use the HPUSBFORMATTER to make the stick bootable. I used a 2gb stick and put it in the usb port next to the headphone connection.
    Unzip the win98boot.zip and put the files on the usb stick.
    after. Wait patiently!!!
    Keep trying this is the only solution
    When you create a bootable usb stick with hp usb disk storage format tool click on ''create a Dos startup disk'' and ''Using Dos system files located at'' click on the button with the dots and search for the unzipped WIN98BOOT.zip files and then click on start when ready put the files flashit.exe and the bios files on the USB stick
    after. Wait patiently!!! In the beginning it looks like nothing happened.
    Good Luck again
    Good Luck again
    Problem Solver:
  • 6 Answers
You need to get you a restoring disk...or brand new drive
Posted on May 24, 2009
Acer Notebook want boot up
Hook a spare monitor to the video output usually on the back, if okay! the inverter board just below the screen is most likely the problem, or the backlight behind the display. But if both show the same issue it is the video graphics card normally built into the motherboard.
Apr 26, 2012 | Acer Aspire One PC Notebook
Acer Aspire 5542 won't boot up. Power light comes on but screen is black and computer not making startup noises
try tapping f8 when booting up that gets you into safe mode. then try doing a system restore to before your problems. safe mode can take upto about 20 mins before welcome screen. try it this may help
Jan 06, 2012 | Computers & Internet
Hello.My ACER Aspire One netbook will not properly load, or load at all actually. It worked fine yesterday, I shut it down.. and when I turn it back on it won't work correctly. It comes to a black load...
Hello my friend. The problem is that the "hard drive" has a lot of bad sectors and the netbook cannot recognise it. The Hard disk might need replace with a new hard disk. Please refer to a computer technician. Please rate my help! Thanks!
May 11, 2011 | Acer Aspire One PC Notebook
I have the Aspire 5810TZ-4761 laptop. Black Screen Won't boot up
Does the dvd drive have a little hole that you can push a paperclip or some other thin itam like a needle in.
This is used to eject the drive manually.
you could also try removing and re fitting the dvd drive, this is usually held in with just 1 screw
Jul 09, 2010 | Acer Aspire 5520-5908 Notebook
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
On boot up of a acer 3050 i get a black screen of death making me believe its a hard drive problem so i change the harddrive and i still get a black screen of death .it showed me the acer screen then it...
i had a similar problem with my acer aspire 4315 (witch i got for free because of this problem :D ) and i just reinstalled vista then it worked just fine
Dec 23, 2009 | Acer Aspire 3050 Notebook
WHEN BOOT UP ON MY ACER ASPIRE THE SCREEN REMAINS BLACK, IS THERE A SOLUTION TO FIX IT?
if you have the restore cd for you computer run it and follow the directions,, if not thats it repair shop
Aug 11, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Acer Aspire AM1201 Desktop won't boot
It would definatly fall under a warranty problem. I would definatly consult the retailer or manufacture prior to anything else
Dec 08, 2008 | Acer Aspire™ T180 PC Desktop
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire One  PC Notebook Logo
950 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
