Question about Acer AL2416W Monitor
Blacks have changed to blue on my PC Monitor
Hi, I have an Acer AL2416W LCD Monitor on a Windows Vista Pro system and now have a problem that has the blacks in any image being replaced by the colour blue. It is running at its native resolution of 1920 x 1200. I have had this monitor for about a year and it has only started showing this problem recently. Any ideas would be appreciated. Cheers, Mike
I'm having the same problem also. My contrast settings are fine. It may have to do with the generic LCD monitor problem of faulty soldering coming lose. Right now when I hit my monitor at the top, or squeeze the corners, the problem goes away temporarily.
Posted on May 04, 2010
    Problem Solver:
  • 6 Answers
Can you check your monitor's device settings (on physical buttons on the monitor) and check for changes to the Hue or contrast setting(s)?
It sounds as if the hue or contrast has been adjusted slightly, just enough to be visible.
Posted on May 24, 2009
My Acer AL2416W is showing a tint of pink in all images I try to display, I have changed the cables with no change. I have taken the monitor to a new computer and it works fine ( no pink at all ). Why is...
The problem is in your old computer, the video graphics card is faulty, you mentioned the monitor was hooked up to the new computer and worked fine.
Apr 17, 2012 | Acer AL2416W Monitor
I bought this acer z193w monitor and everytime I fire it up I get a message saying . My computer runs on windows xp pro.as I haven't got the user's manual, I would like to know why it doen't work, and if...
1) Monitors do not care what operating system you are running, otherwise I wll not br able to fix the monitors if I need to have all the operating system installed in my PC or MAC. You must have correct driver for the video card installed in the your PC.
2) What message are you getting on the screen?
3) User manual: http://retrevo.com/support/Acer-X193W-Monitors-manual/id/7197ag005/t/2/
Jan 21, 2010 | Acer X193W LCD Monitor
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
Al2416w acer monitor comes on says acer then goes black
dose the standby button go orange, if it dose then the screen is going back in to standy, its possible that your graphics card is having problems, maybe if you put some more informationt about what happens then you could get better help.
Mar 17, 2009 | Acer Al2416WD LCD Monitor
Acer AL2416W 24" Monitor switches off and on after a few minutes
open the monitor observe smps capacitor in primary filter may leackage if faulty replace it
Jan 17, 2009 | Acer Al2416WD LCD Monitor
How will my brand new monitor work with windows vista?
Hi , The reason monitor does not sync , You need to reduce the resolution and then connect the Acer monitor and then adjust the display according to your requirement.
Jan 11, 2009 | Acer 19" LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Mounting an Acer AL2416 to the wall
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Mark
Jul 02, 2008 | Acer AL2416W 24 in. LCD Television
Acer AL2416W Monitor Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
