Question about GE GSH25JFR Side by Side Refrigerator
Diagnostic code says defrost. what does this mean?
  • rainbucket2 May 24, 2009
    It seems to be working fine. Just that the light is on. The refrigerator is probably 20+ years old. So I should call a repair person?
  • GE Master
  • 4,654 Answers
Because your refrigerator has a control board everything in the memory is stored there. When an area has a fault the dignostic tend to point you to the area. This could be Defrost element, defrost thermostat or freezer temperature sensor. Have you notice any change in operation since you got this reading during diagnostics? Let me know, Thanks, Sea Breeze
Posted on May 24, 2009
  • John Tripp
    John Tripp May 24, 2009
    If you don't mind the code being there and there has nothing been affected I would leave it alone. Fact is I would not touch a thing!
    If it don't need fixed don't let anyone bother it. That is an odd, first time I have heard of that happening. Thanks for your vote.
What does code 33 mean 2006 Grand Marquis airbag
Mercury Grand Marquis diagnostic code 33 Questions ...
www.fixya.com > ... > diagnostic code 33 > Cars & Trucks > Mercury
Mercury Grand Marquis cars & trucks diagnostic code 33 questions and ... 2006Mercury Grand Marquis air bag light flashes ... What does code po1151 mean.
2006 Mercury Grand Marquis air bag light flashes three ...
www.fixya.com/.../t19845434-2006_mercury_grand_marquis_air_bag_l...
Sep 3, 2013 - It then stay on. I assume - Mercury 2006 Grand Marquis question. ...What does a flashing air bag light mean on a 1993 Grand Marquis? Jul 23 ...
Mercury Grand Marquis airbag code 33 Questions ... - Fixya
www.fixya.com > ... > Tags > airbag code 33 > Cars & Trucks > Mercury
Mercury Grand Marquis cars & trucks airbag code 33 questions and answers. ... What does a flashing air ... 2006 Mercury Grand Marquis air bag light flashes.Missing: mean
Jan 11, 2016 | 2006 Mercury Grand Marquis
I have a 2006 Pontiac g6 gt and my heat or air will not turn on or rear defrost
You have a computer controlled HVAC system ! It has the capability of setting DTC'S - diagnostic trouble codes !
The HVAC control module is a non-GMLAN device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive and ignition 3 voltage circuits provide power to the control module. The HVAC control module during defrost mode will change the A/C compressor LED status from on to off. The control head displays recirc, outside air, A/C and rear defrost feedback status through LED indicators. The control head has a rear defrost request switch please refer to Rear Window Defogger Description and Operation in Stationary Windows for operation. The HVAC control head will display NO COMMUNICATION when checking DTCs or doing a vehicle diagnostic system check refer to Diagnostic Trouble Code (DTC) List - Vehicle and Diagnostic System Check - Vehicle in Vehicle DTC Information.
The rear window defogger system consists of the following components:
Body control module (BCM)
Heating, ventilation, and air conditioning (HVAC) control module
Rear Defog relay
Rear window defogger grid
Your probably better off taking this to a ASE certified repair facility ! You probably have bad Heater / A/C control panel . HVAC Control Module Malfunction
May 06, 2015 | Pontiac Cars & Trucks
Yesterday I changed the bimetal defrost thermostat on my Whirlpool Gold bottom freezer refrigerator after getting an "S" on the diagnostic test. Today I am getting an "S" again. Could it be the heater
Check continuity on the heater. If yes and new bimetal means you are pointing at new control board. But also check whether you have any defrost thermistors in your machines. It might be the defrost thermistor.
Sep 06, 2014 | Whirlpool Refrigerators
Where is the defrost timer / does my fridge even have one?
Most often the defrost thermostat fails there should be a diagram or small manual hidden under the kick panel or taped on the back of the refrigerator. I believe this model uses a computer to control all functions including defrost . There should be a way to run diagnostics on this to tell you your problem if you can find the hidden manual.
Aug 06, 2014 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
Fridge does not start gives error ds
If you like I can help you locate the problem. The error code may be in the service manual but Im not sure about if the manual will tell you how to run self diagnostics if the mother board or the digital low volatage is affected. I enjoy working on the difficult ones if you would like my assistance, Sea Breeze
Dec 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
My refrigerator is not cooling
this means you hasve a defrost problem / problby defrost thermistor/sensor . and or defrost heater .. dh means defrost problem
Feb 02, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Dashligts are blinking, air..rear..ac
At some point prior to your problem a series of buttons were pushed which caused the activation of the CALIBRATION DIAGNOSTICS AND COOL DOWN TEST"
The test can be aborted by doing the following:
Depressing Rear Window Defogger, RECIRC and Rear Wiper buttons.
Cycling Ignition OFF and then ON.
Control will automatically abort after 15 minutes from the time Calibration Diagnostics and Cool down was entered.
The HVAC control module will return to normal operation or may indicate unsuccessful Calibration Diagnostics or Cool down test by LED's flashing simultaneously.
Jul 03, 2008 | 1998 Plymouth Voyager
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
GE GSH25JFR Side by Side Refrigerator Logo
169 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
