Need remote codes for it -have purchased an ellies universal remote but nothing matches
0382,0281,0264,0290. Try these codes. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
SOURCE: Daewoo CTS 2090
try this ENTER MUTE PR UP PR DN ENTRE OR TV IN STAND BY MODE only do as AV SLEEP CLEAR POWER buttons on user remote with in 10 seconds. or go to web site remotes.com
SOURCE: Tivo remote code for Daewoo Tv
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Daewoo TV is one of the following numbers: 0092, 0451, 0672, 1661, 1278.
If these numbers do not work, I would consider buying a newer universal remote. They can be bought at Walmart, for less than 10 dollars.
Hope these suggestions help you out. Please take a moment to rate the info that I have provided, by using the rating system below. Thanks.
SOURCE: tv code search
I can give you these. You should try them until one works hopefully. 0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619. Sometime the universal remotes will not operate everything so be sure to try the power on/off and the volume and try changing channels before assuming the code is wrong. One of these should work...
1180 1200 1215
1197 1165 1258
1239 1198 1036
1194 1289 1331
1052 1217 1202
1158 1039 1160
1214 1285 1269
1301 1376 1157
1123 1232 1051
ok.
