Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Board power is ok but run cpu&fan plz give me answer
915 model motherboard is board power is ok but no run processor no run
  • Intel Master
  • 5,660 Answers
1.Check the Electrolytic Capacitors on the motherboard. Specifically the one's around the processor. These are Voltage Regulators for the processor.
The processor must have DC voltage within a specific range. This zone, or range is very small. Too much voltage, the processor turns off, or won't start up. Too little voltage does the same.
This link will show what Electrolytic Capacitors look like, and what they look like when they are failing, or have failed,
Electrolytic Capacitors are the number one weakest link, of computer hardware failure.
For ease of explanation of construction of them, they look like little aluminum pop cans, they have a rubber seal at the bottom of them, and inside them they have Electrolytic paste.
When the capacitors start to fail, the paste inside develops a gas.
(Hydrogen gas) This gas expands, and pushes the against the seal. The seal's edge pushes out of the 'can', and paste starts to ooze out. So much paste loss, and the capacitor operates at a weakened state. Too much paste loss, and the capacitor fails.
Besides the motherboard capacitors failing, the next area to watch are the one's in the power supply. Power supply's have voltage rails inside. More specifically, they have a 3.3 volt rail, a 5 volt rail, and a 12 volt rail. Voltage may be thought of as the 'speed' of electricity. Amperage may be thought of as how much.
Volts times Amps = Watts.
If you have a power supply with weak, or failed capacitors, you won't be getting the full wattage your computer needs. Your motherboard power light will light up, other lights will light up, fans will spin, and the harddrive sounds like it's working.
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning it's platters, uses about 3 to 5 Watts.
PROCESSORS use 55 to 125 Watts!!
So you see you can have lights lit, fans spinning, and the harddrive spinning, but when BIOS tries to turn the processor on, it can't!
Not Enough POWER!
Posted on May 24, 2009
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
Sir, i have got intel pentium 2.8 and board asus p5kpl-cm and my cpu temp show 86 and fan speed near 2500.plz give me a solution for high temp. thanx.
check if the cpu heatsinkl fan if fully tight. And try to apply the white paste( will be available in stores) on the cpu then seat the heatsink and tight it firmly
PLS REPLY OR COMMENT. THANKS
May 20, 2011 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
When computer Switch On button press computer will not be start and processor fan aslo not start so which problem accured on mother board or cpu? But Motherboard light is always on board provide power...
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 07, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
After turend on there are 3 beeps, no display, ram are ok tested
It is a memory problem. Verify if they are plugged in the mainboard slot.
Jul 13, 2010 | Intel DG965RY Motherboard
CPU Running Fan not recognized by motherboard M7VIG 400
Check out
1.the heat sinker is tightly fixed on the processor.
2.check and clean the dust in the processor ad the coolingflood on top of the processor
Jun 30, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
P4m800 m7 rev 3.1 & intel pentuim d 915 compatibility
Based on the information given here, the p4 d processor is supported by your motherboard. There should be no problem in making the switch.
Jun 10, 2009 | EliteGroup P4M800-M7 Motherboard
MOTHERBOARDS Compatibility with this processor model.
the model you have given is not the correct model Number. Please check the link below & see where it says " E2160" this is the model number for the Intel CPU. please chk on your CPU & let me know the model you have. also most intel motherboards will support most of the CPU's. anyhow if you can give me the CPU model i can recommend some intel motherboards.
May 26, 2009 | Intel Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
