Question about APC BACK-UPS XS 1300VA LCD 120V (BX1300LCDX) UPS System
F06 fault APC BACK-UPS 1500VA
F06 always appear everytime i switch it on
IB4G2008
  • 3587 Answers
SOURCE: APC Smart-UPS 1500VA
yeppers...those APC units sometimes kick the monitoring software. sometimes you need to unhook the connection cables(like a reset) so that the firmware can 'unlock' which can cause that christmas tree effect on the panel lights.
Posted on Feb 06, 2008
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
in the end solution is you have to bring it nearest apc service.
if you loaded more than its max. capacity at past, the sensor of power is geting burn the sequare wave generator IC.
so you need help with that, olso complicated.
I live the same position with my rs1000, horrible :((
Posted on Jan 09, 2010
  • 25 Answers
SOURCE: I have a APC RS 1500 BACK-UPS and is locked up in
Check all MOSFET.
Posted on Mar 09, 2010
Testimonial: "If I knew how to ID and check MOSFETS this would really help. Joe"
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
I have a kenmore he3t quiet pak4 front load washer. First of dhl code. I ordered a new door lock and put that in. Then I got a f06 code. Put back in old lock and still only get f06 code. The other...
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its either a faulty MCU, or faulty drive motor.
Nov 03, 2014 | Washing Machines
Im always having this BSOD "BLUE SCREEN OF DEATH' EVERYTIME i open it BSOD always appears.. and everytime it appears i do the" repair(recomended)" then it turns on.. and when i...
Hi Faith,
BSOD's can be caused by ....well, lots of things...Drivers, hardware incompatibility, operating system, etc. Also diagnosing the cause would require above average knowledge.
I would suggest upgrading all your hardware drivers to latest releases. If not fixed, a clean re-install of Windows should fix it. (remember to back up your data)
Jun 11, 2011 | Computers & Internet
''write protect'' is always appearing on the camera screen everytime I take photos. what should I do?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 19, 2010 | General Electric A735 Digital Camera
Appears dark color and made my camera phone always stand by..
move your finger... retart stop taking pictures in the dark outside... NEWB!!!!!
May 09, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Please could you advise my Panasonic video recorder has a F06 error code and the cassette is stuck is there anything I can do?
You appear to have a K-deck mechanism. F06 means mechanism locks during unloading. The cause of which is the load motor and the carriage alignment. Which might explain the stuck cassette. If you look around the net for "Panasonic K Mech" you should find a load of free service information on it.
Mar 31, 2010 | Televison & Video
What does the F06 code mean? My machine appears
The F06 code usually indicates a motor related problem. Some potential causes are loose/corroded connections of the wiring harness between the motor and the motor control unit (MCU) or between the motor control unit (MCU) and the central control unit (CCU). Sometimes this problem can be fixed by removing and reseating the electrical connections at these locations, but unfortunately I believe that your motor is shot. I say that because one of the ways to test the motor is to remove belt and turn pulley by hand. It should rotate freely. Then, run motor without belt (which you said you did). If the motor will run without the belt, but won't run under load (with the belt on), then this is a sign that the motor is bad. Really sorry for your trouble and I hope this helped. Best wishes.
Aug 24, 2009 | Kenmore Washing Machines
Panasonic NV HD620 Error F06
You appear to have a model that uses the K Deck Chassis.
F06 in that case stands for: "Mechanism locks after unload". The cause being either the loading motor or the carriage alignment.
May 07, 2009 | Panasonic NV-HD680 VCR
Panasonic VCR has F06 code
You appear to have a K Mech model. F06 is the code for the mechanism locking after unload. The cause being something to do with the loading motor or the way the carriage is aligned.
Jan 29, 2009 | Televison & Video
APC BACK-UPS XS 1300VA LCD 120V (BX1300LCDX) UPS System Logo
6,529 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
