Question about Dishwashers
Just bought 4 months ago.was flashing ER and now no power to ANY buttons
Just bought a frigidaire piece of junk DW 4 months ago and at first it was flashing ER and now i have nothing. none of the buttons work. looking around on the internet this seems to be happening to everybody. was there ever a recall on this and/or how do i fix the problem? or better yet can i get my money back? what a complete waste of money
    Problem Solver:
  • 6 Answers
Frist you should call the after sales servic agent in your country.
but you can try unplug the Dw AND CHEEK THE ERGTH CONECTION.AND TRY AGAIN
Posted on May 24, 2009
Bosch silence plus 50 dba is showing error code h01
I believe this is a filling or water flow error. Make sure all the plumbing stuff is OK look at the valve under the sink that feeds the dishwasher. make sure it has not gotten turned off. Sometimes with hot water and cold also a chunk of crud will break off somewhere and get lodged blocking or restricting the flow. You may also have a filter somewhere on the DW to prevent junk from getting in. If there is a piece of crud a likely spot for it to be is at the valve connection under the sink where the DW hose connects to the hot water line. You can try unhooking the DW supply hose from the shut off(turn the shut off OFF first) and seeing if there is any junk in it. Shake the hose about 8" back from the end to try and send any junk in it flying across the kitchen. Also open the valve a bit with a bowl under it to blast any junk out. also see if it seems like a decent amount of water comes out to rule out any upstream plumbing issues.
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Rinse only error, interrupted cycle
Double check that the float on the basin isn't stuck. It is mushroom shaped and inside the DW. Open the door, slide out the bottom rack, and look for it. Found it, great. Gently move it up and down a couple times. Does it move freely? Was it stuck? No? Ok Then lets try something else.
Call the manufacturer and ask them questions. If it is less that a year old, it is covered under basic warrantee. Do not delay.
Also check other common issues with DWs: Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 11, 2014 | Frigidaire FGHD2455LF
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Just replaced the control panel on a Frigidaire DW #PLD4375RFCO. Had the dreaded "ER" flashing problem. All was working well ....about 15min into the wash and now "HO" flashes, and...
Probably the thermostat. Remove the kick panel and look toward the back you will see a circular piece with 2 wires attached on the top. Turn off the power to the dishwasher, unscrew the thermostat and order a new one.
May 21, 2011 | Dishwashers
Dishwasher Frigidaire Professional Series model PDL4555RFC indicator is flashing Er and other words in red
The dishwasher is junk...poorly designed. Masterboard for electronic buttons keeps shorting out because the dishwasher vents from the top. have this dishwasher and know first hand. had it for about a year and its been fixed several times
Aug 07, 2009 | Frigidaire Professional Series 24 in....
My dishwasher is flashing an ER signal
The moisture is probably getting in through a defective door gasket allowing it to leak.
It will burn out your computer board again if left unattended.
Mar 31, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
