Question about LG DLG5988 Gas Dryer
Not heating my dryer has been repaired twice now. the first time it wasn't heating, they said the problem was the "thermistor" which was replaced. it worked fine for a few cycles then stopped heating again. this time, the thermistor was fine but some sensor needed to be reset. it worked fine again and now it is not heating again. the cycle is running through fine but the dryer is just not heating anymore. what else can i do or shall i just go buy a new dryer?
  • Anonymous Apr 02, 2008
    Not drying enough
  • Anonymous Mar 08, 2009
    Where is the reset switch?
The over heat sensor is very sensitive on this dryer and the older they get the more sensitive they are..
It has a re-set button on it for just that reason.
If the vent pipe or any other part of the venting system is the least bit blocked it will trip the over heat sensor.
A NICE SAFTY FEATURE.
Posted on Dec 05, 2007
  • 94 Answers
Check the exhaust vent and make sure it is completely cleared out.
Posted on Oct 21, 2007
I have a Whirlpool Cabrio dryer, model WED6400SW, that displays an F23 code. What type of problem does the F23 code signify?
Your heating circuit is out of range. Most of the time, it's the thermistor that has gone bad.
Sears has the replacement:
Thermistor 8577274
If that doesn't do it, then the next most common culprit is the main PCB board.
Oct 19, 2014 | Dryers
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
Whirlpool Dryer WED8300SW0 will not start... All lights are lit.. makes clicking sound.... Thermostats have been replaced twice
Hi dgouge...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 21, 2011 | Whirlpool WED8300S Dryer
Is there a way to check the thermostat on the heating coil of a Bosch 500 series dryer with a meter? I've got no heat but I have 240 to the unit and the heating coil has contiunity. The thermal...
Hi mk3327...
Try these solutions to your problem:
Check your Wiring
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse, by removing the wires from each of the two terminals and checking each terminal on the thermal fuse,thermostat,thermistor, ect once you have the wires removed.
Then you do not have to tape the wires together as described above.
Sep 08, 2011 | Bosch Dryers
Dryer takes twice as long to dry; dryer is about 7 years old
Hi mfeliciano...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 30, 2011 | Roper Dryers
Trying to repair my maytag mde4000ayw dryer. This is the 3rd time in 5 years that the dryer has stopped heating. The last 2 times, we ordered and put on a new heating element and it worked. This time, we...
Hi
Check your Wiring
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Jul 28, 2011 | Maytag Dryers
My dryer is approximately 2 yrs old. prior to my problem with it, it wasn't drying clothes properly and had to run couple or several cycles before the clothes were sufficiently dry. it did not matter...
Hi dladucer...
Check your Wiring
Jul 26, 2011 | Estate TEDX640JQ Electric Dryer
Replaced thermostat and sub cutoff twice. Dryer works briefly and then it does not heat. What's the problem?
Hi gxanthus...
Check your Wiring
This is a FREE answer, Please take time to rate me
Jun 29, 2011 | Whirlpool GEW9868K Electric Dryer
My HE2 front loader dryer flashes f22 and stops. A repair man has replaced the thermistor twice, but it is still flashing the same error.
This means the outlet thermistor, the one on the blower housing, is open. But since the thermistor has been replaced twice and the error code still flashes (make sure it is cleared after the replacement by pressing STOP twice), the wire harness (including the connectors) connecting it to the electronic control board is cut open or the electronic control board itself is faulty and not detecting the thermistor connected.
Check the connections and the continuity of the wire harness and replace or repair it if found cut open. Consider a faulty electronic control board if the wire harness and the connectors are intact and the thermistor is known to be 100% good. Normal thermistor resistance is around 8500 ohms to 13500 ohms at room temperature (27-21 degrees centigrade).
Mar 09, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Whirlpool model LER8648LW0 that is about 8 years old. It gets a lot of use. It used to dry well, but now takes almost twice as long to dry an average load. Towels take about 1 1/2 hours on high...
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
If the coil is ok, then you want to check the thermistor/thermostats. Remove the wires and tape them together one at a time with electrical tape and turn on the machine and see if it heats up ok...if it does then replace the thermostat/thermistor that is bad.
DO NOT LEAVE THEM TAPED TOGETHER. BECAUSE THIS BY-PASSES THE SAFETY OF THE MACHINE.
Good Luck,
Hope this helps
Oct 13, 2009 | Whirlpool LER5636P Electric Dryer
LG DLG5988 Gas Dryer Logo
229 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
