Question about Sylvania 6427TE 27" TV
Screen got wide; nasty acrid smell like chlorine or ozone started
Hi, we have a 27" Sylvania TV. It was working fine, and then the picture got wide, the remote stopped working, the sound started coming in and out (mostly out), and then there was an acrid smell, but the tv was not hot. The model is 6427CTA, and it's about 10 years old.
  • 46 Answers
One or more electronic components was burned or deteriorated inside the tv.
Replace the TV.
Posted on May 24, 2009
Are there any tvs that do not have an ozone smell?
Smell of Ozone comes from the anode cap of picture tube based TVs. If anode cap is firm and good, there will be no ozone smell at all.
Jun 06, 2012 | LG 50PX5D 50 in. Plasma HDTV
My 27" ( aprx 6 yrs old)Tv first had only a horizontal line across the screen about 1/2" wide, good sound but no picture, now it only clicks like its turning on and off when you plug the tv in, no pictue...
It has gone into a self protect mode where it will shut down because you have a fault in the frame stage of the TV (horizontal line). This will most likely be a failure of the frame output IC. Replace this & you should restore the normal picture.
Oct 11, 2009 | Sylvania Televison & Video
Squeeling/hissing sound
You are losing high voltage; if you sniff around the top or back of the set, you may smell ozone.
Pull the AC plug on the set overnight, remove the few screws holding the rear housing on, use a CLEAN (or new cheap) paint brush and if you have a vacuum with a hose, bring it along too. The CRT (picture tube) will be nasty, full of dust that is picking up moisture and creating a path for the high voltage to discharge and you need to clean it with the brush and it's better if you hold the vacuum hose close by so you can **** up the dust loosened by the brush.
If you clean it well (dry, not wet), the problem should be gone.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV picture is not good
from what your describing it sounds like a resolution or ratio setting on your t.v. you can change these setting on your cable box and t.v as well this seems to be the setting on your t.v. since you have already unhooked the cable box. if changing the settings doesnt resolve your issue you may have some failed components on the pc board that could be repaired by a repairman v/s purchasing a new one. hope this was helpful....
Dec 16, 2008 | Sylvania 6427TE 27" TV
Nasty moldy smell inthe MAH2400A
a cycle with just hot water and chlorine bleach will help but you may have to work at it a litle longer to get the door seal any cleaner in future run a short cycle with bleach and leave door open between use as much as possible..there is a new tablet shaped cleaner out now that may help in routine cleaning ckd with local dealer or repair personel also may ckd grocery shelf
Jun 09, 2008 | Maytag MAH2400A Front Load Washer
Air purifier
ozone is what you are smelling,also purchase a extra collection plate from ionic pro so the cleaned plate can dry complete.
May 10, 2008 | Ionic Pro TURBO Air Purifier
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Air Purifier smells like chlorine
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Dec 13, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Tv screen
hi there, working sometimes means there's a lose solder at the vertical section. see the vertical ic, check the board for some lose connection and cold solder. do some test. ty
Nov 09, 2007 | Sylvania 6427TE 27" TV
Sylvania 6427TE 27" TV Logo
202 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
