Question about Electronics - Others
My flash drive will not download
Troed tech support from transcend-got no solution
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
Dec 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i connect transcend jf v30 16 gb pen drive it takes lot of time and computer doesnot respond and it displays as unreadable format or corrpted
There are three possible
3. Bad sector
Oct 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a JF V33 Transcend USB and I tryed JFSW and JFSW2 to try to reformat the USB but, they both cant read the USB I need help ASAP plzzz
Yes
go to www.transcend .com download the driver Transcend 4GB JetFlash 110 USB 2.0 Flash Drive Media from the tab given in the website. and enjoy using transcend./......................
Mar 28, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protect on my 8gb transcend jetflash
If you dont have any switch for 'write protection' in the USB body, then download the utility called 'Jet Flash Recovery Tool' from trancend web site. It could help you.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 4 GB PenDrive
hi...
Transcend Downloads:http://www.transcend.nl/Support/DLCenter/index.asp
Transcent Tech Support:
http://www.transcend.nl/Contact/CuTechsupport.asp
 If the dealer is a retailer, he is supposed to give you a refund, or a replacement.
You can email Transcent:
Service@transcend.com.tw
In the documentation that came with the device, there must be some warranty policy information.
Transcend USB Flash FAQ:
http://www.transcend.nl/Support/FAQ/index.asp?axn=queryFAQ&srhWhatBU=PBU&Func1No=10&LangNo=0&FldNo=18
thank u rate me!!!
Feb 16, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Transcend 2GB Flash Drive
Most of the flash drives that I have bought had a limited lifetime warranty.
Most of these devices require a driver. XP and Vista come with the popular drivers pre-installed.
Have you investigated the requirement for a driver?
I don't know about the laws where you are, but where I am located there is something called "Consumer Protection". If the dealer is a retailer, he is supposed to give you a refund, or a replacement.
I would get in touch with Transcend and complain about the dealer. Then I would put in a formal complaint to the consumer protection about the dealer.
Jerry G.
May 29, 2008 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Electronics - Others Logo
19 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
