Question about SanDisk Sansa e260 MP3 Player
It is unable to format and it shows "device was unable to complete the format"
My sansa mp3 player is not formating it shows the device was unable to complete the format please help me
  • johan jollens
    johan jollens May 11, 2010
    what sansa is it?..
    try this:
    turn off your sansa and turn off computer
    do not touch sansa and start computer
    when logged in on computer open "my computer"
    now connect your sansa while it is off
    now close the auto window that comes up "if it does"
    now rigth click the sansa and format if not working...
    lemme know your os, sansa player
    President:
  • SanDisk Expert
  • 650 Answers
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Posted on Jun 02, 2009
I just got my sansa mp3 off of amazon and it does not work what do i do
STEP 1 - Connect the device to the computer 1. Remove the battery from the player’s battery compartment. 2. Put the hold/lock switch to lock. 3. Plug in your device to the computer.
STEP 2 - Format the device 1. Double-click My Computer. 2. Right-click on the player, which might show up as a Removable Drive, select Format. 3. Click Start. 4. Click OK when a "Format Complete" dialog appears. 5. Click Close.
How To Download MP3's To My Player.
Sansa Mp3 player frozen? How to reset and...
Sansa View: is not recognized by my...
Solve your MP3 Player Connection Problem.
Check out these tips posted here I think they are the best ones for MP3 players.
Mar 19, 2010 | SanDisk Sansa m250 MP3 Player
Unable to see and delete( or format) songs in player
o delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Jan 29, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk sansa problem
It isnt a fat or fat 32 player..It is a mp3 and or a wma player. And you could be missing the proper device driver depending on your computers os..Pre 2000? file compression file format
Jun 29, 2008 | Mach Speed TRIO Onyx MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
i tell you connect to the computer your device
and right click on your device and format it
Jun 09, 2008 | SanDisk Sansa Clip MP3 Player
I cant delete videos from my 4 gb sansa
change it to fat32 and format it. it should work
May 16, 2008 | SanDisk Sansa e250 MP3 Player
Unable to format
Try quick format, it should work...!!! Else use DOS to format..!!!
Feb 10, 2008 | SanDisk Sansa m230 MP3 Player
Message states unable to format
Make sure you dont have Rhapsody, or Windows Media Player open. Go to My Computer>Device Name (e260)>Right Click and select FORMAT. If that doesnt work, change the mode on the device Settings>Mode or USB Mode and repeat. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e260 MP3 Player
Trying to format
Are you formatting thru My Computer? If so try using Computer Management. Right click on My Computer and select Manage. On this window select Disk Management on the left. On the right side at the top, your drive should be listed. Right click on the device and select format. If your device does not show up, change the devices mode and try again. Device>Settings>Mode or USB Mode. Best of Luck.
Sep 20, 2007 | SanDisk Sansa E280 MP3 Player
Two problems with my mp3 player
Hi Mina. An internal memory corruption might have occurred on your player, and would need to format your player through "Disk Management" (I'm assuming you have Windows XP or Vista). Here's how: (1) First, set your player to MSC mode by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MSC" (2) Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" (3) Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" (4) On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa E250. The lower section also contains the drive # pertaining to your E250. Right-click on either drive letters pertaining to the E250 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. In general, Disk Management is more the effective tool for formatting your E250 and assuming the format processing completed without any errors, you may now use your player as you would. You may want to set the mode of your MP3 player back to "MTP" (if you're going to download subscription songs -- otherwise, just leave it in MSC mode) by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MTP" In case you get the error "Unable to Complete Format" or the format process is unable to complete, you may want to call the SanDisk Tech Support guys for more advanced troubleshooting (I call `em when I'm at my wit's end lol) I hope it works :)
Jun 02, 2007 | SanDisk Sansa e250 MP3 Player
Problem With Format
Hi, you may want to try using the manufactures preferred method or better still update the firmware. It is available at http://www.sandisk.com/Retail/Default.aspx?CatID=1376. Please let me know if this woprks out ok with your Sansa e260. Regards
Apr 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
317 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
