Question about Whirlpool GD2SHGX Refrigerator
Refrigerator gets extra hot on top and side
The top and side of frigerator get extra hot
Refrigerator (GE) freeze some of the food on the top self, blowing hot air out of vent in ice box also top of refrigator got extreme hot.
Posted on Aug 12, 2011
  • Whirlpool Master
  • 4,654 Answers
The only thing that I can think of that would cause this is heat strips that are placed around the door frames to prevent moisture from forming around the doors. The way you have explain what is happening is an indication that the strips are out of control. If you can find the model number located on the bottom of the fresh food compartment door frame behind door get that for me. The problem is unsafe and should have your full attention until resolved. The parts cannot be replaced and can short out. If you have a local dealer or someone to talk to about the problem would be a good
idea. If you can find model number let me know. The model number above your post appears to be incorrect. Thank You Sea Breeze
Posted on May 24, 2009
My refrigerator is hot! To be clear, the frig is cooling, but the divider between the frig and freezer is so hot that it almost burned my arm! The lower part of the freezer is defrosting as well.
Your condenser grill under your frigerator is dirty and not able to get rid of the heat. If you take off the front grill and the back panel and vacuum it out or better yet, blow it out with an air compressor, it should solve your problem.
Also make sure that the condenser fan is operating because that would also cause the same symptoms.
Aug 07, 2011 | Hotpoint HSS25GFP Side by Side...
The strip between the freezer door and frigerator door gets very, hot -- it could burn your hand. What is causing this?
hi make sure the condenser is clean and the fan is running the condenser in in lower back of refrig jim
Oct 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Center panel between doors in hot to the touch
This is due to the condenser over heating, if you have cleaned the coils then the most likely suspect is the fan that keeps those coils cool. See this link for more information on this.
Hot rail
Jun 03, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kenmore Top Freezer not getting cold (freezer or refrigerator), fan works. Occasional click down by compressor? Any advice appreciated. Trying to fix cheap as this is an 8 year old 2nd frigerator we keep...
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The frigerator and freezer are not getting cold enough.
It sounds as if your unit is low on freon.You will need to have a quailfied repair person to refill.
Jul 02, 2009 | Refrigerators
Frigerator is working but, refrigerator is not working at some points
Your freezer coil may be frozen over causing air circulation to stop. Check for frost build-up in freezer compartment. this is an indication of a fault in the defrost system timer or heaters.
May 18, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
218 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
