Question about Acer Aspire One PC Notebook
What's an IP address?
Whenever I try to get online my computer says that my IP address can't be renewed
    Problem Solver:
  • 5 Answers
Internet provider address. ring your provider and they will sort it
Posted on May 24, 2009
    Scholar:
    New Friend:
  • 84 Answers
An IP address is nothing but a string of numbers separated by periods that identifies each computer attached to the Internet.There are two types of IP for a single computer namely Private or local IP address ,you can find the private or internet IP address using the command prompt Start - CMD - IP config/all .And the second one is public or network IP address you can find this address by visiting the site IP-Details.com .
Posted on Jun 03, 2013
  • 85 Answers
An IP address is identifier of your pc on a network. sorta like your address. Same as your house you cannot have 2 pc with the same address. To renew it you can go to Start->Run and in the box type cmd This will bring up a DOS interface and type ipconfig /release then enter and next type ipconfig /renew
    President:
  • 1,383 Answers
Ip adrees is a uniue addres in network
U got this eror because of dhcp server problem.
restart your dhcp server then type in cmd"ipconfig /renew"
thats it
Hpow u change ip adres
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
I cannot get online with my neighbor's internet service. They have an open access signal with Time Warner cable and my message is that I need to renew my ip address to make a connection. I have
To renew the IP address under Windows XP, you issue the following two commands in sequence under command line (aka cmd):
ipconfig /release
ipconfig /renew
Feb 19, 2012 | Dell Computers & Internet
My acer aspire 5630 will no make the connection to the internet using the wireless. if i hook it up hard wired it works fine. I also tried a USB wireless but it would not make the connection that way...
Try to release and renew the IP address:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Dec 13, 2010 | Acer Aspire 5630 Notebook
I have 3 wireless connected and 1 computer that is connected via wired lan to this router. The problem is whenever I use the computer with wired connection, I computers with wireless connection cannot...
On the "wired" computer:
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Type IPCONFIG /ALL
Press Enter
Note the IP-address assigned to the Ethernet adapter.
Note the date/time at which the router assigned the IP-address to your computer.
Repeat on one of the "wireless" computers.
The IP-address should *NOT* match the IP-address of your "wired" computer, and the date/time should be close, but not identical, to the valuesl from the "wired" computer.
Any error-messages from the 'IPCONFIG /ALL' command?
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
IP ADDRESS IS WRONG CANT GET ONLINE
Tips:If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
Oct 23, 2009 | E-Machines eMachines Desktop PC
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
Laptop will not get an IP address
In command prompt
1.c:\>ipconfig /release
then
2.C:\>ipconfig /renew
try this steps
Mar 30, 2009 | Dell Inspiron 1501 Notebook
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
Tips:
Oct 28, 2008 | Gateway Computers & Internet
I have 2 desktop computers. im connecting a router to run a wire to the second computer the modem. when the computers connect to the router though, neither will get online. theyre showing full connection,...
Probably, a problem with the IP addresses. A conflict between the two computers. Try to connect to the internet with only one computer turned on. Let the other one turned off. Find out the IP address with the command ipconfig. You may have to renew it (ipconfig /renew).
Then, go to the router config: See the manual of your router. You may have to reserve the 2 IP addresses in your router configuration.
May 24, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
220 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
