Question about Olympus FE-190 Digital Camera
Broken screen I have had the Olympus FE 190 since May 2007.  At the moment, the screen is broken.  It appears to have some physical damage, but since I bought a protective case, I can't think of how it would happen.  when the camera is off, you can see a large darker spot on the screen.  when turned on, the top half of the screen is white, with the large black spot running through.  there also seems to be a lighter thin line in the spot.  the bottom half of the screen is fine and ready to take a picture. the camera can still take a picture and put them online.  thanks for any help offered!
  • 2 more comments
  • woops Nov 03, 2007
    I have exactly the same problem - caused by having the camera in my pocket when I tightened my lap safety belt too tight and exerting undue pressure on the camera. No steps taken to resolve as yet, the retailer has told me it would cost as much to repair as to buy a new camera - approximately $300 Australian. Any tips would be most welcome.
    Colin
  • svankoug Dec 13, 2007
    Same problem, wasn't abusing the camera and simply bumped a wall when it was in my jacket pocket and the screen cracked and can't see any image at all! Must be a weak link in Olympus camera, they should have a protective cover over the lcd.
  • Anonymous Feb 10, 2008
    olympus fe-190 camera lcd has been broken
  • realjesus May 27, 2008
    when the camera is off, there is a dark line through the top right of the screen, when i trun it on- the line renains black, but the outline of it lights up red.
    the top half of the screen (to the left of the line) lights up, bet every other pixel is white, and the area to the right of the line completely white.
    the bottom half of the screen works fine, except for a few blue and red colour bars going through it.
Sounds like the LCD. Setting anything next to it, bumping it may crack the screen
Posted on Jan 21, 2008
SOURCE:
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
I have got lines on my screen horrizontally the lines are in blue and green color the moment screen starts the lines appear it seems to be physical damage but i am not sure about it want to know can it be...
hi,
For you to be able to verify wether if its a physical damage or just a software problem,try to go to the BIOS and see if the line still appear,if there is,that means that there is something broken inside of the monitor,most possible the LCD it self that needs to be replaced,but if the line is not there,just try to update the graphics driver.
Hope this will help..
Jan 17, 2011 | Dell LATITUDE D530 COMPATIBLE LAPTOP LCD...
Camera is not showing up on computer
try connecting and disconnecting a few times then blow on the battery hole and reinsert them
Oct 25, 2009 | Olympus FE-370 Digital Camera
My olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
Jun 01, 2009 | Olympus FE-210 Digital Camera
Lcd broken where can i replace and wha tis the
get a new camera sorry it is a specalty wiring very expensive assembly machine
if it is truly broken. just get a new one
cost of repair is at least 1/2 of new camera
there is no repair of the lcd
Feb 21, 2009 | Olympus FE-210 Digital Camera
Broken screen
You will need to call Olympus to discuss the repair process and they will be able to give you the cost for the repair service. Their telephone number is 800-622-6372 option 2 and then option 3
Nov 01, 2008 | Olympus FE-180 Digital Camera
Olympus FE-280
1 year warranty on olympus products, but does not cover physical damage such as impact, water, or sand
Jul 18, 2008 | Olympus FE-280 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
Olympus FE-190 Digital Camera Logo
281 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
