Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Control panel not working and no lights
Refrigerator works fine makes ice but the panel dosn't work and the lights dont work on the inside of the fridge
  • sethh2o2000 May 24, 2009
    i wont beable to fix it just yet but thanks for the help.
  • 6,784 Answers
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
Posted on May 24, 2009
  • 3 Answers
I had same issue. The control panel had been set to Sabbath mode. Hold down the "DOOR ALARM" button for 3 seconds. Then lights will turn on on both display windows. Scroll using the + and/or - sign on the left side display until "SAB" is shown. Then scroll using the + or - sign on the right side display until OFF is shown. Finally, hold the "DOOR ALARM" button down again for 3 seconds. All should be good to go!
Posted on Feb 04, 2012
  • Nal Bottego Oct 12, 2015
    I cannot express how thankful I am for this post it really work and save me $500. Thank you.
Control panel off lights in fridge and freezer on but not working
Unfortunately the control panel is probably defective. But check for power to the panel. This controls the temp of the freezer, fridge and the solenoid control valves for the water and ice maker. What is the Year, Model and Make of the refrigerator?
Mar 22, 2015 | Refrigerators
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Control panel
Its faulty control panel, needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
Ice Maker will not stop making ice
the beam is defective. Its called an optic eye it does tell the IM that the bins full and cuts power to IM when beams dont see each other.
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water dispenser not working
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
Jan 07, 2007 | GE PSW26SGRSS Side by Side Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
616 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
