Question about Toshiba 53H71 53 in. Rear Projection Television
Toshiba 53" Dull Screen. No brightness and Contrast.
Could not see the picture. The brightness, sharpness, contrast adjusted and tried at the maximum. Still the same. We need to put off all the lights in the room and make dark, then only the pictures are visible and its blurred too. How can I sove this problem. Or any replacement for this item. I am in Kuwait.
Please help me to solve this problem.
sreejeet@gmail.com
    President:
  • 4,402 Answers
I would guess the tubes are going...I would still have serviceman check it out
Posted on Jan 22, 2008
How do I alter the colour, brightness, and contrast?
Go to menu, go to screen settings or display settings. Should bring up the sharpness, contrast, color, brightness controls. Follow directions on screen to adjust. Hope this helps!
Jan 29, 2016 | Televison & Video
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
Contrast is way too bright, not screen brightness, contrast. is there a contrast adjust button?
Right click on your main screen. Go to properties, or graphic properties, then you will find there is a contrast adjustment within. Usually under color correction.
Mar 24, 2011 | Toshiba Portege 4000 Notebook
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My jvc 52g 887 had the bulb replaced 6/1/10. The picture is very dull with very little contrast. Is it the bulb?
A poor output lamp won't reduce the effective contrast so I expect it just needs slight adjustment to the contrast or brightness.
Hope that helps
Jan 25, 2011 | JVC Televison & Video
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Squares visible in bright colors
Turn down the contrast to about 55-65% of maximum. Also turn down sharpness to about 10-20% of maximum.
If ther is a Contrast Plus option, or digital contrast, turn to minimum or off. (Dependant on TV)
This is a common side effect with digital television.
Jan 23, 2008 | Philips Magnavox 42MF521D/37 Television
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Toshiba 53H71 53 in. Rear Projection Television Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
