Question about Philips FWD798/37 Shelf System
Abdulla.d72@hotmail.com rear speaker is correct but sount is not coming properly
  • 28 Answers
Try interchanging the polarity of the rear speaker you could have a better sound output, if still no improvement power amp. I.C. of your rear spk. is defective
Posted on May 24, 2009
Rear speakers make no or not match sount.
you need to do some settings in the software.if you are chatting over skype then go to options and see the audio options and select the camera microphone.but still you need a head phone to talk
Mar 24, 2012 | Computers & Internet
My m819 mother board my pc instal window 7 but sount not instal
yes probably the system comes with a lower or higher version of operating system . what you are to do is not get the driver if you are sure there is a speaker attached to the system or probably an inbuilt speaker then after your installation of the sound driver compatible with window 7 then you test it by playing a music file and thats all you need.
Apr 30, 2010 | ASUS M2N-MX Motherboard
No sound on new 55" flat screen w/ built in speaker system
chack sount if that is decrese plzzz sound up ....after it ll't done .....plzzz chack from macanic
Mar 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No sound from Rear Speakers
Ok, so we know the connections are correct, the speakers all work properly.
The only other thing I can think of is: is your PC actually sending signal to the rear speakers? Have you set it to 5.1 surround, and are you playing something in surround sound? The best way of checking (personal preference) is use some kind of racing game, reverse into something and you'll get a broken window effect in the rear speakers.
So, check to see if your PC is sending the rear effects, double check to make sure the actual speakers work (you could plug an MP3 player into the rear speaker input.
If this doesn't help, feel free to reply.
Jan 11, 2010 | Audio Players & Recorders
No sound from cenre and rear speakers
Is there an output section for the speakers on the back of the receiver? if so, make sure to properly install the speaker wires into the correct connectors. It should be the same as for the front speakers. If not, then you will not be able to install center and rear speakers.
Make sure there is nothing wrong with the speakers, or the wires them selves. If you are positive that everything is installed correctly, try using a new batch of speaker wire. If the speaker wire is pre-installed or already attached to the speaker from the factory, you might have to call and report a faulty product or try to find the break in the wire yourself. To make sure the speakers are working properly, be sure to plug them into the same connector as the front speakers to see if they receive the signal. if noise comes out of them when plugged into the front slots, then the speakers themselves are fine, and it is an issue with the wires or the unit itself.
Last, if it is not the speaker, or the wires, then you will have to remove the cover from the receiver or remove the wire inputs from the back of the receiver and make sure there is no connectivity problems with them. There might be a frayed wire, or a wire that has come loose, or a soldering issue. If so, you can try to tackle it yourself, or you might have to bring it into a repair shop, or call Sony.
Hope this helps at all. :D
Last, if you have tried new wires,
Aug 09, 2009 | Sony Audio Players & Recorders
Audio problem
first of all check sound setings in windows.
take help from below link. http://www.fixya.com/support/t1720012-audio_problem
contact me if problem persists.
Good Luck!
neo
Feb 27, 2009 | Intel D945GCCR Motherboard
Can n ot get rear surrround speakers to work
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Feb 02, 2009 | Denon AVR-1708 Receiver
AKAI 54 inch
sounds like your convergance ic's shorted on you.
you can replace the fuse in the power supply and disconnect the conv board and see if it comes on. if so order new ic's and check all resisters for the correct values.
good luck
Jun 09, 2008 | Akai PT5598HD 55" Rear Projection...
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Logitech x-530 5.1
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting. Go here to get an operations manual for this setup. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=d*11Q7xi&p_accessibility=0&p_tbl=9&p_id=2924&p_created=1126107772&p_olh=0 Good Luck
Mar 22, 2007 | Logitech X-530 Computer Speakers
Philips FWD798/37 Shelf System Logo
117 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
