Question about HP Pavilion tx1000z Notebook
Resolution problems when using an S Cable
I currently have my PC hooked up to my TV using an S Cable and the audio through a diffrent cable. When I used it before it seemed to come through just fine. However, for some reason now that I try to put the computer screen on my TV the resulation is all messed up. all the pictures and words are graular and messed up. how do I fix this? I have restarted both the computer and the TV twice.
  • 85 Answers
Change the resolution on your laptop try higher resolution
Posted on May 24, 2009
Brand new emerson led tv has this red tint to it. I have the cable hooked up to the at&t u verse cable box and just a basic cable cord going from the cable box to my tv. Would a hdmi cable fix this
You would definitely want to try using a HDMI cable.
Your current hookup requires signal conversion too many times resulting is quality loss and more chances of introducting errors and this might be where your red tint is coming from.
Assuming AT&T is providing you digital signal at 720 resolution or higher, the box then has to convert back down to composite video (340 resolution) in order to send it to your TV over the basic cable cord. Your TV then takes this low resolution signal and blows it up to fit your nice new flat screen TV.
Skip all that and use HDMI and you'll get the best picture that your provider is sending you. The digital input stays digital and is passed onto your TV over the digital HDMI cable with no loss to video or audio.
Nov 29, 2013 | Televison & Video
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
ProView has a bad cable connection. Other tvs hooked to the same cable don't
It could be the tuner in the set is the problem--there is since the rear inputs work fine a way to "get around this".
Get a Cable box that has the audio/video outputs on the rear and connect to one of the rear inputs on the set--want to watch cable--go to that input and use the box to change channels.
If the tuner is bad you are likely going to have to replace the entire board it is on--not cheap.
The rear inputs bypass the tuner and all the signal circuitry from it.
Also if signal routed via rear jacks you should notice a better picture and sound quality.
SD TECH
Apr 22, 2012 | Proview PA-32JK1A 32 in. LCD Television
What cord do I need to connect my acer notebook to the t.v for netflix
this is pretty easy. Since you're acer aspire doesn't have an HDMI out port, then you're gonna need a VGA cable to connect your acer's video signal to the TV.
This cable should do: http://www.amazon.com/10ft-Resolution-mo...
Now, since it's not HDMI, you won't get audio coming out the TV, only your laptop. But if you want audio out your tv, all you'll need is audio cable, which you can connect to the headphone jack (audio out) and then into the AUDIO IN jack on your tv.
the audio cable: http://www.amazon.com/Cables-Unlimited-A...
After this, just hook it up while your tv is turned on, switch to the VGA channel on your tv, and a window should come up on your tv asking you to configure the settings. For audio go to the control panel while the audio cable is hooked up, go to sound settings, and switch the default audio to speakers, or headphones, im not so sure what it is on a netbook
Aug 16, 2011 | Acer Computers & Internet
I have a 42 in lcd i hooked my computer up to it the computer sound isnt comeing out of the tv how do i get it to come out my suround sound there is a jack like a head phone plug where i hooked the...
Now i assume you have connected the Computer using a VGA cable ( 15 D pin connector )bobhifi_41.jpgbecause if you had used an HDMI cable the sound would have come by default. The VGA cable only carries analogue Video signals. So you will have to get 3.5 mm phono to 2 RCA cable to connect the sound out of the PC to the TV's audio in socket ( next to the VGA socket labeled audio IN )
Apr 22, 2011 | Sanyo 42 in. LCD TV
Connected samsung TV to PC vi VGA cable as suggested by samsung support. Visual working correctly, no sound output. Tried hooking up standard audio jack leads with l-r splitter to TV to get audio. No...
You need a seperate speaker system when your tv is on vga there is no option to recieve a sound input. In fact if you hook your cables for sound back up to the tv you will probably find that there is sound but on a diffrent input channel. The other option is to use a diffrent type of connection like hdmi if your computer and tv support it which DOES support audio and vido throught the TV.
Mar 09, 2011 | Samsung Televison & Video
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
PS3 no picture problem..
Try using RGB cables and unplug the HDMI cable from the PS3, then while the PS3 is off, hold down the power button/sensor on the PS3 untill you hear a beep or a few beeps. This will force the PS3 to automatically detect the TV/cable resolution settings. Hope this works.
Aug 25, 2009 | Sony PlayStation® 3 (80GB) Console
Audio Trouble hooking PS3 up to HD
Hi there, Have you checked that the HDMI Cable is inserted into both your PS3 and HDTV correctly ? if the cable moves about in the HDMI port that causes static sometimes ! Also check that your cable isn't damaged.
If the problem persists. i would just Use your Composite (Red,Green,Blue) connection from your TV to your PS3. you said it doesnt have static problems. and Using the composite cable you can still get the Full 1080p Resolution on your TV that the PS3 can Up-Scale to!
Hope this Helps ?!
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
59 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
