Question about Maytag MSD2756G Side by Side Refrigerator
Front door dispenser panel stopped working, lights are off.
Front door dispenser panel stopped working, all lights are off.
  • anetty170 May 25, 2009
    I agree with you. The Sears technician will come tomorrow. I'll let you know. Thank you very much for your interest in helping me.
  • 6,784 Answers
HI. the dispenser circuit board(s) will need to be replaced. there are two boards that work in unison. replace them both. this will fix your issue.
Posted on May 24, 2009
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool GD25FFCHT01 dispenser not working
It might also be the cable that connects through the hinge door to main unit.
Feb 08, 2013 | Whirlpool Refrigeration White Side Trim...
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Refrigerators
GE Profile refrigerator panel on front has stopped responding to requests for ice. It give water, but no ice. Any ideas on what is needed?
Yes, we will need to check the wiring from the motherboard to the dispenser controls. Also we need to test the door switch. The door light switch works two ways by turning on light when open and turning on dispenser controls when closed. Sometimes the door switch is bad. I have a link and will work with you to solve this, Let me know, Thanks, Sea Breeze
Apr 18, 2010 | GE Profile PSS26NGS Side by Side...
The water and ice dispenser stopped working, nothing on the control panel works at all
Looking over your wiring diagram I would go straight for the freezer door light switch. Part number 241547901 or 1037569 Switch-light lamp,freezer door. It is used as an interlock to disable the dispenser controls while the freezer door is open. I would unplug refrigerator and remove switch by prying out of its slot in the door frame. Use an ohm meter to test both ways. It has a three wire connection that while door is open lights are on and dispenser control disabled. When door shuts lights off and dispenser should have power. Let me know what you find, Thanks, Sea Breeze
Mar 19, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
Ice maker and water dispenser front panel lost power
Check the power connection for the door.. It is either under the hinge cover on the top or under the kick plate in the bottom.. Just un plug and re plug if it seems like the wires are fine
Good luck
Feb 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
206 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
