Question about Amana ABB1927DE Bottom Freezer Refrigerator
Kenmore 26 fridge. when therm kicks it out, won't come bk on.
@ 18 yr old unit. Recently, I came in one day and it was off, thawed out, NOT 2 GOOD !!! I tapped on the cover panel where the thermostat is, and it came on. Now every so often, when it is satisfied with its achievement, it will cycle off and it may or may not come back on. If it does not come back on, all I have to do is tap on it the thermostat/ control cover lightly, and it kicks on. I have that panel cover off now and the thermostat assembly loose and laying down on the first shelf, and it is running. I am an electrician/electronics and technical maintenance mech, but I have very little fridge experience. I have my Fluke in there and have been probing just out of curiosity. Could someone please try and assist me ? I would greatly appreciate it !
    President:
  • 1,136 Answers
Hi, I can help.
Do you need conformation or a part #? Please let me know so I can assist you.
Vic
Posted on May 24, 2009
  • 46 Answers
I had this problem with mine, and the thermocouple inside the freezer needed to be replaced. It was not possible to do without releasing the "freon"..so we just got a new fridge.
My thermocouple was in the upper freezer area in the back behind the wall fan area.
Fridge kicks in louder than usual for 20 seconds and clicks off.
the pistons in side the compresor are compermized.as long as the unit contiune's to work's than you are good.there is nothing you can do to fix this.
Nov 28, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
1 yr old Kenmore fridge (18 cu ft top freezer mdl 970-41924) has very long defrost cycle - freezer contents partially melt, fridge warms to 50-55 F. (Normally runs at 38-40 F.) We keep several litres of...
Either the defrost timer is going out or it could be your defrost bimetal thermostat that is located behind the back wall in your freezer. Both parts are cheap and easy to install. I would replace both.
Sep 09, 2009 | Kenmore Refrigerators
Slow dripping water from top freezer into the main fridge
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Oct 23, 2008 | Whirlpool Refrigerators
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Admiral Refrigerator/Side by Side
compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
May 27, 2008 | Admiral 26 cu. ft. Side-By-Side...
Sears Kenmore ColdSpot Frostfree Frosting up/Not working
You have a defrost problem. You need to determine which one of the parts is faulty. The defrost timer on that model should be behind the kick plate in the center front underneath. If you turn the little knob by hand you will hear a load click when it gets to the defrost point and the unit should shut off. Check in the bottom of the freezer to listen for water sizzleing or for water running down. If it is the timer is not advancing and needs replaced. If not you will have to take the back off the inside of the freezer to see if it is the heater or the defrost thermostat. Unhook power before taking panel off or replacing any parts.
Apr 24, 2008 | Refrigerators
JCD2295HES side by side not working correctly
yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Mar 05, 2008 | Jenn-Air JCD2295HES Side by Side...
I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Jan 24, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
85 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
