Question about Whirlpool MH1150XM Convection/Microwave Oven
My whirlpool microwave model# MH1150XMB-0, light in microwave stay on, keypad work, when i try to heatup any thing i press start it will not come on or heatup any thing
  • Whirlpool Master
  • 9,047 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on May 26, 2009
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
MH1150XMB
It's important that high-current devices like microwaves be on their own dedicated breaker.
I would suspect the 20A fuse and then the oven cavity thermostats, in that order.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (such as the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Oct 11, 2012 | Whirlpool GH8155XJ Microwave Oven
Model #mh1150xmb-0 The light bulb under the microwave burnt out (with a bang) this morning. Although the lights and clock come on the microwave it won't start.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too, and on these models, can prevent them from starting or running.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 18, 2010 | Whirlpool MH6150XL Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
One of the interior latches, or hooks,(rear) which hold the metal rack in place has melted and has begun sparking while the oven runs. Im wondering where to find a replacement and how to access the latch...
Ken, I have the same problem . . . I was told by the company that I need to replace the overn as the inside wall is burnt so it will happen all the time. . . have you found a soultion or heard any differently/?
Dec 07, 2009 | Whirlpool Microwave Ovens
The guys here gave me good advice and that I probably need a new magnetron for the Whirlpool MH1150XMB-0 (runs but does not heat food). I think I can replace the magnetron but dismantling this hood...
DO NOT!!!!!!!!!!!! undertake this job unless you have a pair of discharge leads and you know how to discharge this appliance the capacitor holds a charge large enough to kill you for about a month
Sep 28, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave Whirlpool Model: MH1150XMB The keypad numbers 1,2,3,4and 5 suddenly stopped working. any suggestions?
you'll have to buy a new control pad, or if you can solder you may take display out and see if the connections are broke to those buttons and solder them back.
Sep 16, 2009 | Whirlpool MH1150XM Convection/Microwave...
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
Microwave oven door removal
First you have to tell why you want to remove the door. The door seal is important to keeping the radiation from excaping and is not recommended to fool with it.
Dec 28, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Hood/Combo
This is a common problem with the control panel assembly, which we repair nationwide for $39.95. This is most often caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. If you or a friend decide to disassemble it to send the control panel in for repair, we have *critical* safety & disassembly, info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 22, 2007 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool MH1150XM Convection/Microwave Oven Logo
836 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
