Question about Panasonic PV-GS39 Mini DV Digital Camcorder
Battery problems When i try to turn on my camera, it doesn't respond, as if the battery is dead. Fine. But, when i plug in the battery to the charger, the charger acts like i have not even plugged anything in, it doesn't respond.
  • 752 Answers
Re: Battery problems
Sounds like the battery is shot. Does the camcorder work ok on the AC cord?
Posted on Nov 29, 2007
0 characters
3 Points
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
Handycam not holding charge even with new battery.
Sometimes the batteries will build up a memory if they are only used for short periods of time and never used to the point of going completely dead, so possibly getting a new battery online. B&H photo is a pretty good site.
I know some chargers have an output to the cameras battery connector that powers the camera, and if that is plugged into the charger it will not charge the battery simultaneously.
If the camera is working when plugged into the power source it usually turns out to be a battery problem. Sadly the only choice it to buy a new battery.
Feb 29, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Kodak Play Sport pocket video camera will not power up or charge new out of the box.
I had the same problem. Specifically, using a microUSB cable to charge the camera worked fine for a few uses. One time I let the battery go very, very dead. When that happened my camera would not charge when I plugged it into the computer or charger. The light on the power button never lit up either. I couldn't find a way to fix it until I tried this . . .
The fix I am about to describe is repeatable - works every time (for me). Unfortunately it is not easy for everybody to accomplish.
On the bright side, if you do this once and fix the problem then you should not have to do it again . . . well, unless you drain the camera battery too far again in the future.
Items needed:
1: A 3-terminal 3.6v battery charger for an external lithium battery pack. The unit must have clearly marked positive (+), negative (-) and temperature (T) terminals that allow alligator clips to be connected. I have such a charger for one of my old digital cameras. Remember to check that it charges 3.6v battery packs and has 3 accessible terminals that are clearly labeled.
2: Your camera's battery pack, removed from the camera.
3: Three wires with alligator clips on both ends. Ideally each would be a different color. Black, red and yellow will be used in this example.
4: A piece of stiff clay or similar substance that can be shaped.
5: I don't want to sound snippy, but you will need awareness of the risks and rules when dealing with electricity. For example, do not short the terminals of the charger. Do not use a charger that does not match the voltage of your camera battery. There are more "do not's" than I can list here. If you are unsure, "do not" do this.
1: If at any point the project starts getting hot, immediately unplug the charger and disconnect the wires. Do not apply power to the charger in until electrical connectons have been properly made. Consult a knowledgable person if you have any doubts. You might void your warranty if something goes wrong.
2: Place the camera battery into the clay to immobilize it. Shape the clay to allow the contact/charging terminals of the battery to be exposed. Save a spare piece of clay for later (read ahead to see how big).
3: Clip one end of your black wire to the negative terminal of the battery charger.
4: It is impossible to "clip" the other end of the wire to the battery. Instead, use the spare piece of clay to hold the wire in a position where the correct terminal of the battery can be "leaned" against the wire.
5: Repeat steps 3 and 4 for the positive terminal of the charger and battery, using the red wire.
6: Repeat steps 3 and 4 for the "T" terminal of the charger and battery using the yellow wire.
7: Inspect the product carefully. Your project must be able to sit still without shorting, etc for about 1/2 hour or so.
8: Carefully plug in your charger, and avoid disturbing your wires.
9: The charge indicator should illuminate on the charger. If all is well, monitor (I mean really watch) your battery for about 1/2 hour while it charges up. Carefully feel the charger and battery for heat, especially at the beginning.
I don't recommend allowing it to charge for any longer than 1/2 hour. The point is to allow your battery to be charged just enough to fix the problem. It could be risky to attempt a full charge.
Theory behind the idea: The software running within the camera is responsible for configuring the USB port and internal circuitry to enter a charge cycle. That software only runs properly after the camera "boots up." In order for the boot process to complete successfully the battery must have enough power to sustain the unit for a few seconds. When the battery is "very drained" it will not supply enough power to the camera long enough to allow a complete boot process, therefore charging does not occur. This leaves the camera in an unusable state where it cannot be charged or turned on in any way. In my opinion this is a design flaw that could be easily overcome via software by raising the minimum threshold before the camera ceases to allow recording/playback.
It is a shame that Kodak has not come clean about this. For affected individuals, they may do well to ship out a new charged battery and a software update.
Dec 25, 2010 | Kodak PLAYSPORT High Definition Camcorder
Battery won't charge. camera power won't turn on. don't know if the battery is permanent dead, or the camera itself is no functioning.
If you have the charger that plugs into the camera, try plugging it with your battery detached. The camera should run at this point, this would point to a bad battery. If not you ether have a bad camera or a bad charger. If it is under warranty take it back, if not take it back and see if they will let you try a battery or charger from their displays. Battery specialty stores are real good places to go for assistance with battery problems. They may be a bit more expensive but they usually are quite helpful about things like this. You should be able to find one near you in your yellow pages. Another good source is Radio Shack.
Aug 08, 2009 | Sony Handycam DCR-SR40 Camcorder
My canon fs 100 doesn't turn on
I took the camera to the representative and we started various tests such as:
Tried My battery in OTHER camera .... not working
Tried OTHER battery in MY camera .... works
Tried charging MY battery in OTHER Camera .... works
Tried MY battery in MY camera and charged .... worked
Bottom end is that my charger is not working although it heats when "charging".
Now i will look at the pins in the charger to see if they are working or not.
Whatever the case .... getting a new charger.
May 29, 2009 | Canon FS100 Flash Media Camcorder
My camera will not turn on. It doesn't matter if the battery is attached or not or if the camera is plugged in. when switch on my camera the red lights on top comes on. but the screen is dead and it will...
i am having a problem with a borrowed everio (gulp) -
it will only power on if attached to the wall charger - otherwise, it wont recognize the battery - although the battery is full and works fine with other everios. an expert said they were made poorly and i just have to take it in to service
Jun 28, 2008 | JVC Everio GZ-MG30 Camcorder
Won't start
how old is the battery? if it's more than 2 or 3 years old, it may not hold a charge. swap a known good battery and see if it works.
Dec 10, 2007 | Panasonic AG-DVC30 Mini DV Digital...
Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (
Feb 11, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Apr 13, 2006 | Samsung VP-W75 Camcorder
Panasonic PV-GS39 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
