I have a LG wm3988hwa and it pumps cold water into the drum while drying. I have determined that it is not the 5way valve. Any ideas?
  • nick243 Jun 04, 2009
    The solution for this problem was the 5-way cold water valve. That is all that was replaced and it works perfect now!
  • 1,543 Answers
I have not looked up your model number, but on LG combo washer/dryers, drying requires addition of some cold water in the vertical vent area to facilitate condensation (and thus moisture removal) from the dryer's air stream. This cold water should then pass under the drum without contacting the clothes. I'd check the pump inlet filter at the front left of the machine, and I'd remove the back of the machine and then the big rubber connector at the lower left side (as viewed from the back of the machine) and remove any lint which may be impeding water flow at that point.
Posted on May 24, 2009
How can i just fluff clothes in a LG wm3988hwa
Put it on drying cycle, coolest temp, shortest time.
Mar 18, 2016 | LG WM3988HWA Front Load Washer / Dryer
LG WM3988HWA water filling drum and overflowing during dry cycle
Solution for finding the right part, the (5 way) Valve assembly:Part Number: AP4998623 made by LG
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520795
I got the company link from LG. If the link does not work, go the the main website and enter in the model number. appliancepartspro(.)com
p.s. I found a service manual for my unit when I removed (by unscrewing) the inside plastic piece of the pump filter. It was located to the right, in a plastic bag.
p.s.s. I checked my water pressure, it was 90psi. I think this is why my flow limiter 'shot out' the valve and into the tubing.
p.s.s.s. The dryer heater assembly, the duct out, fan, and tubing was filled with so much lint, I was surprised anything could get through.
Nov 20, 2011 | LG WM3988HWA Front Load Washer / Dryer
Every morning there is 3"
THats a bit tricky determining which water valve it is...while the one way to be sure would be a process of elemenation the cold water valve is most likely going to be the one. A fairly easy way to determine which one is,is turn off just the hot water tap and cold water tap seperatly over the course of a couple days and see when either is off if it still has water in the drum...meaning if with the cold water faucet off does it still have water in the morning and vice versa for when hot faucet is off
so with the cold faucet off no water in tub from overnight its the cold water valve
if no water in tub when hot is off its the hot
GENE
Sep 07, 2011 | Bosch WFK 2401
Display code FE... what needs to be done
FE in an over fill error. (the pump should automatically come on to drain water) If the machine is not overfilling, check the thin hose that goes to the water level switch. If it is overfilling you will either need to replace the inlet water valve if it is filling with no power to the vavle, or the main control board if it is receiving power in the FE condtion.
Oct 08, 2009 | LG WM3988HWA Front Load Washer / Dryer
WM3988HWA Error NO Water Source
CHECK THE WATER FILTERS AT THE BACK OF THE UNIT THEY ARE PROBABLY DUE FOR A CLEANING.
Feb 28, 2009 | LG WM3988HWA Front Load Washer / Dryer
WM3988HWA Pumps Cold Water in Drying Mode!
Replace the 5 way valve. get the old flow restrictor out of the drying cold water line before reconnecting. It came out of the valve to cause the problem.
Oct 17, 2008 | LG WM3988HWA Front Load Washer / Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Drying problems
This usually indicates that the fill valve for the drying cycle is faulty. In short you need a new cold water valve assembly. (this will fix this issue 90% of the time) Otherwise you may need a new control board.
Inside of the machine (you will have to remove the top cover from the machine) is a valve assembly attached to the cold water line. This valve assembly consists of 2 or 3 individual valve bodies . The one on the right hand side of the assembly usually controls the cold water inlet for the drying cycle(this is necessary for proper condensation drying to take place). There is a black hose which attaches this part of the valve assembly to the wash drum. With the water shut off and the power removed from the machine, remove this hose from the valve and look to see if it has a small red (usually) plastic insert. This is a restricter insert which limits the water flow into the tub. Without the insert the tub will fill with cold water in a short amount of time.
Aug 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
321 people viewed this question
Top Washing Machines Experts
