Question about Panasonic SA-HE200 Receiver
Overload.comes on all the time now.
Ive had nowt but problems .. cant use the dials on it cause they change on there own,now the overload comes on all the time. so  it cant be used.. ive had it only 8 years..
just info.. not related.. my onkyo lasted thirty and still sounded great .just coulnt change the station.. wish i still had it..
thanx people hope you can help
  • 1 more comment
  • marzwillis May 24, 2009
    aperently just replace the fuse.. if the fan is turning when needed..so ill do that cause my fan works.. no where to find said fuse..theres two of em in there...
  • marzwillis Oct 26, 2009
    i think we should all take the same actions.. as to the panasonic group... i wrote to them twice now .. no results,this thing has been a thorn in my side since the first year i had it.. ill not be buying panasonic products again...
    hey thanx .but im not a repair person.. i wouldnt have a clue .. i just got quoted $280.00 canadian for a fix.. needless to say ill be grabing that thing right back.. but ill not be buying panasonic agin..
I had the same problem and all I did was take the built in fan off and the plug it into an extra adapter and the plugged the adapter in the back of the amp so that the fan would come on as soon as you turned the amp on not when the amp got hot. I have had it like that now for about 4 years and the only time that it overloads is when I have music just cranked or there is alot of bass coming out. So try that and see what you get.
Posted on Sep 22, 2009
My dryer stop heating, what are the possible reasons?
possible reasons for dryers to stop heating are as follows in order of how frequently i find them occuring
(1) !!!!!!! clogged dryer vent someplace !!!!!! (includes ext. lint traps) if i had a penny for how many times ive heard "Ohh i didnt know it had one of those" id sure be a millionare now!!
(2) overloaded !!! "no mam you cant put that whole beds sheets set in there at once " this of course causes over temp safety to shut heat off
(3) problem with either gas supply or electric supply to machine
(4) thermal safety switch defective (sometimes refered as thermocouple)
(5) door switch interlock problem
(6) blower drive belt broken
(7) drum drive belt broken
(8) drum rolller problem (causes #6 and#7) look for forign objects stuck in there
before working on your own dryer i ask you to consider the number four cause of home fires in americia = clothes dryers !!!!
Feb 18, 2015 | Dryers
Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
Aug 03, 2011 | Frigidaire Compact Air Conditioner
Ive tried to ignite the hot water gas cylinder and im not how do i know if its even working.? Cause we cant see the pilot light.?
it will all depend on what brand the hot water service is
although you should be able to put the dial on pilot light setting which is normally light an * on the dial
hold the dial down whilst pressing the clicker (piezo ignitor) normally can take between 10-60 seconds then turn the dial clockwise to the on position and turn your temp gauge with numbers to around 4-5 and it should make a noise when the heater ignites !!!!!
see how you go
luke the plumber
Mar 13, 2011 | Heating & Cooling
Timer worked for years. Just replaced lights. There were (8) but now there are (10). I didn't do the work and didn't know the wattage (and am not positive, but this looks like the unit). The lights work,...
Download manual for Malibu 200 Watt power pack
According to Malibu website information, your power pack is correct size if lights come on.
The way to figure is this
10 bulbs x 18 watts each = 180 Watts
so 200 watt power pack is good
Does the manual override work?
Rotate the on-off button counterclockwise
If override does not turn lights on-and-off, then timer has a short
Does the center dial turn when power is on?
If the dial is not turning, then power pack is kaput, or time of day is not set
Did you reset the time of day?
How to set time of day:
Put your trippers in place
Red = ON
Black = OFF
Plug in power pack
Rotate arrow (colored blue in diagram) as follows
Turn dial clockwise to present time of day (diagram shows 9 o'clock)
Turn dial one or more full revolutions, then return to present time of day
If center dial is still not rotating after setting time of day, it's time for new $50-80 power pack, unless you put a $15 timer on that plug. A cheap timer might work ... keep it going for couple more years.
Oct 08, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
My 1.6 club astra cuts out occasionally cuts out on approach to a junction as i dip the clutch the revs just drop away.is this am air flow sensor problem
Try removing the throttle pot and cleaning it with carb cleaner this will sort it out as any heavy carbon deposites will cause your problem
Mar 08, 2010 | 2000 Volkswagen GTI
I have a 1994 s10 2.2 its got a major miss i cant find out ive done a plugg change 2 times plug wires 2 times. ive done compression check fuel pressure check. new fuel filter. 1st and 2nd gear sorta runs...
weve had alot of coil packs go bad on that engine and also it could be the ignition control module will lose fire on one side and cause a bad misfire also very important gm had a technical service bulletin on the fuel injectors causing a misfire due to leaking o-rings and injector failure. always make sure you bleed down the fuel pressure from the fuel rail before removing any injectors if you dont it will cause engine damage
Jan 17, 2010 | 1994 Chevrolet S-10
Theres no spray coming out but theres solution in. ive checked seals, turned off left it and primed it. it works for 1 stroke then im bk to square one again. please help me
You need to check the seals. It is loosing prime after one stroke. I had the same problem and found obstructions causing a seal to leak and allowing air into the sytem. Take it completely apart and clean thouroughly.Also do you have the dial to choose between carpet and tools? If so make sure its not on the tool setting. I have done this numerous times only to find out i forgot to change it back
Sep 29, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Set up
which key are we talking about .is it the wep key
Dec 07, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Panasonic SA-HE200 Receiver Logo
222 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
