Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Grease fittings I have grease fittings on the mandrels underneath a Craftsman lawn tractor. How do I get to them? Can the tractor just be tipped up on its back? Where would I put a jack so as to not damage the tractor?
  • 10,865 Answers
You can drive the front tires up on a set of tire ramps and grease the front and then drive the rear tires up on the ramps and grease the rear.
OR just lay on the floor and reach under using a grease gun with a flexible delivery hose.
If you do use a jack just be sure to jack on the frame of the tractor as opposed to any sheet metal.
Posted on May 24, 2009
How is the mandrel shaft assembly removed from a broken housing and replaced into a new housing? Are there any shop diagrams I can look at?
Use a wood block to hold the blade back while removing the top bolt. then remove the blade. finally knock the shaft out from the top, should free up with a slight hit on the grease fitting and come out through the bottom. Goes back in the same way.
Apr 28, 2016 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Is it normal for the pulley driven mandrels to become too hot to touch??
No, if they are too hot to touch the bearings need replacing. Any grease that is recommended for wheel bearings is fine for your mandrels. Regards Phil.
Jul 03, 2012 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a dual blade deck on a Craftman's 15.5 OHC rider mower that needs to be greased. The blades make a loud racket when they are engaged. Any idea where to grease the mowing deck?
look closely and you will see the blades under the deck are physically bolted to the same gizmos which are spun by a belt on top the deck. these gizmos are called mandrels, and that is where the lube has to go. sometimes the top of the mandrel has a grease fitting and you may have to pull the deck safety shields off to get to them, and sometimes there are grease fittings on the bottom of the mandrels and you have to pull the deck off and turn it over to get to them. Then sometimes they are "lubed for life" with no grease fittings and you have to go to a small engine repair shop and buy new ones. if you get the deck belt off and there is any slop in the mandrel, then you are too late for grease and new mandrels are in order. they cost less than 50 bucks apiece. generally remove the deck, the blades, the belt, the pulleys, and a few bolts and nuts and reinstall new in reverse order. replace all the belts while you are at it.
Aug 07, 2011 | Craftsman Garden
Craftsman 42", 18.5 lawn tractor: blades are hitting in the mower deck. Blades are new and deck is balanced. Is it wear on the Mandrel - Shaft? Mandrel bearing?
Oh boy!!! Welcome to the craftsman worst design of their mower decks CHEAP!!!!! I had to replace my mandrel on the right side, side where the grass shoots out several times!! Cheap aluminum casting ****, one or more of your ears on the mandrel probably snapped, if you have an air wrench they are not too bad to replace, the screws that go into the mandrel are self threading and is easier to work on with air wrench but can be done with socket set, hope this helps!!!! good luck!
Aug 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The mandrel on left side is not spinning properly and making a growling noise.
it sounds like the bearings are bad either grease the mandrels see if it goes away
Jun 26, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
How do i take out the mandrile
remove the blade, remove the deck from the tractor, remove pulley covers, remove the deck belt, remove the bolts holding mandrel to deck, remove the mandrel. reinstall in reverse order.
Jun 23, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman mandrel replacement::?????HELP
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Jun 23, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
How to replace mandrel spindle
If you have the deck off, you can use a 7/8 socket on an impact gun or if it's still on the tractor, Leave the blade on, wedge something there to keep blade from turning and use a breaker bar on the top nut. Be sure when you put the pully back on that the washer is underneath the pully, NOT on top. Dwain
May 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering is difficult....
Put some grease in the grease fittings located on the steering knuckle using a grease gun.
May 13, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
720 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
