Question about Canon MX700 Office All-In-One InkJet Printer
Bad printing Every time i want to print something it prints it but the letters have shadows and on some lines only print half of a line. My printer has ink in it i don't know why this is happening, it use to print good. I asked my teacher because i turned in a project and the printing is all bad he told it could be a cylinder thats in the printer which may have some tiny trash or something but i don't know were it could be or how to open the printer. Hopefully you guys can help.
  • 30 Answers
You have to get it readjusted!
Posted on May 24, 2009
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
I have canon lbp 2900 printer when i print first line shadow is also printed in the middle of page and middle line shadow is also is printed in the last of page. and some of line shadow is also printed.
Repetitive ghosting defects like this are caused by either a bad drum in the cartridge or a damaged or worn fuser assembly. Try a different cartridge first, but make sure you print at least 50 pages to make sure that any toner residue is cleaned of the fuser in the printing process. If the defect is still there then you will need to either repair or replace the fuser.
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again...
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
Mar 16, 2011 | HP LaserJet 1020 Printer
HP C4280 printer always prints with a shadowed letters, especially with the black ink. i think it started when i was installing a new cartridge and i didn't insert it at the correct angle, so i may have...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 08, 2010 | HP Photosmart C4280 Aio Printer
The top half of letters on certain lines of print are offset by about half a letter space from the bottm half of the letters. Usually but not always the same lines. help please
This usually indicates a need for a new print cartridge or the printer head is dirty. You can run the automatic printer cleaning utilities. Note: do them several times.
Also, if you are a little handy, use Qtips and rubbing alcohol and clean the print head.
Sep 18, 2009 | Epson LQ-590 Matrix Printer
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Nov 23, 2008 | HP Photosmart 8450 InkJet Printer
L7780 won't print on edge of paper
it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
Right half of A4 has not print correctly
How old is the printer? try to go to the print options and do a realignment of the print heads. if its an old printer possible might need to clean the print head if that didnt work maybe bad print head.... take it to the pro. good luck!
Mar 21, 2008 | Canon BJC S300 InkJet Printer
Canon MX700 Office All-In-One InkJet Printer Logo
90 people viewed this question
old marine
old marine
