Question about Panasonic KX-TG5632 Phone
Can't get handset to register
Cleaned out my garage and found Multiple Handset Sysytem made by Siemens (bought from SBC) 2430
The handset says "please register" I hit ok and it just says "searching" i lost the manual and if I recall I need to hit a button on the base unit, but can't remember. Please help!
  • 4 Answers
Panasonic manual says hit the Intercom button and when the "OK" thing comes on the LCD screen, push the button underneath the OK.
Posted on Jan 26, 2008
Hold down the page button after you enter the system pin - must be done within 3 minutes of entering the pin - and voila!
Posted on Jan 09, 2008
I don't have the same phone but what worked for mine (Uniden 646) was to place the handset in the charger built into the base unit.
Posted on Jan 01, 2008
How to register 2 Bell Cordless handsets on 2 bases?
Multiple handsets registered to one base works well.
The extra base can be used as a remote charging
dock without registering a handset.
Trying to register a handset to two bases is neither
possible nor useful.
OTOH, the specific model number was
not given. While I have never heard of
registering a handset to more than one base,
nor made it happen by accident, maybe we
all do "...learn something new everyday...".
What is the specific model number, and the
date of manufacture ? Thanks! a r t
May 17, 2016 | Bell Lands Phones
Display keeps saying 'searching'
I don't have this model but I have had two Siemens phone systems. Typically, when the handset says "Searching" it is trying to connect to the base station (the part actually connected to the phone line). This can happen if the handset is too far from the base station to connect to it wirelessly. It can also happen if the handset has become unregistered from the base station (or was never registered to begin with). If the distance issue is not the problem, look in your documentation for how to register the handset and give that a try.
Sep 07, 2014 | Siemens Gigaset 4215 Cordless Phone
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Bought a spare 3111 handset and cant connect it to my base. it looks as if it was connected to another base at one time. screen just says "connecting..." and there is nothing I can do to clear...
The handset must be registered to the base unit if the system has multiple handset ability, the manual will tell how to register the handset. If the system is a two handset system then only two handsets can be registered.
Dec 08, 2010 | Vtech Cordless 6041 Phone
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
Keeps going back to Register HS
Thats because there are too many handsets registered to base OR it can't find the base. Did you set it to register then pressed the little tab in on the bottom of the base? You have to hold tab down and keep phone close to base (a foot or so). If handset goes out of reg mode, you have to put it back in, then quickly press base tab down again before it stops.
Dec 17, 2009 | Siemens Gigaset A140 Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Registering a handset for the siemens 2400 handset
Siemens Customer Service They offer a 24 hour help line and
can walk you through the process.
http://www.wedophones.com/Manuals/Siemens/Gigaset%202400%20User%20Guide.pdf
One handset is preregistered to the base. You had two. You indicated returning the pin to 0000. To do so, you must have entered a code to deregister the pin and go to factory defaults. Your best option is to call and let them walk you through a clearing and registration process if the above links does not suffice to the quick reference guide.
Feb 19, 2018 | Siemens Gigaset 2420 Phone
Adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
May 21, 2007 | Siemens Gigaset SL30 Cordless Expansion...
Panasonic KX-TG5632 Phone Logo
247 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
