Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water comes out of ice maker so i had to shut off the ice maker. The water coming out the tube on top just kept on coming out, the ice maker in the past sometimes would stop working for a couple days and then all of a sudden start working again i do`nt get it, could you help me.
  • 331 Answers
This is the water solenoid that lets the water in. Areyou ok with working on the unit.
Posted on May 24, 2009
I went the water valve and spent $80 for the valve, only to find that 1) I didn't need it and 2) I couldn't get my money back. I ended up getting the whole unit for the ice maker for $74.00 You will have to do some searching to find it that cheap, but you CAN find it.
Took me about 5 mins to replace and it has been working fine.
P.S. If you need a water fill valve, I can give you a deal on one.
Posted on May 27, 2009
    President:
  • 1,136 Answers
Hi, did you have to shut off the water supply to get hte water to stop? Sounds like the water inlet valve is going or has gone bad.
Please get me a model # and I can look the part # up for you.
Thanks
Vic
My ge ice maker not making ice and no water coming in at the top to fill water inlet was leaking so bought new one and changed it and still no water to ice maker but the water is working to fill a gla
there are two valves,one for ice maker and other for dispensenser,also check the tube that filles the ice maker and make sure that it's not frozen,sometimes the tube freezes but this is still caused from bad water valve
Oct 10, 2014 | GE Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Apr 24, 2010 | LG LRFD25850 French Door Refrigerator
No ice....slow to refill ice tray
You need to check the water pressure coming from the water shut off to the frig. Sometimes right at the shut off debris gets in and the water comes out really slow.
if this isnt the problem then it could be one of three
water valve not opening 100% (replace)
ice maker timer is not working properly (replace)
the tube that feeds the ice maker is frozen
Mar 28, 2010 | Refrigerators
Ice tray is full and fill tube continues to run.
Your water valve is bad or the ice maker itself is bad.
Start with the water valve. Im not familer with inglis but this should help. find your water supply line frome the wall to the refrigerator, this should lead you to the water valve. Unplug the machine and then unplug the wires that are conected to the water valve. now you can check to see if the water stoped. (( of course the water has to be turned back on if you shut it off ))
If you still have water coming in then the valve is stuck open and will need to be replaced.
If the water quit coming in the fill tube then the ice maker is bad and will need to be replaced.
Jan 12, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Tube feeding ice maker comes off
Good day,
Common problem. Remove ice maker, and make sure tube fits all the way to the rear and seats properly.
Then reinstall ice maker and telescope front part of file tube until it fits into ice ice maker properly. (retaining clip in place).
For the cost, a new fill tube makes sense. Also.........
If the water valve leaks slightly after shutting off during a fill cycle, a plug of ice will build up inside the the fill tube, pushing it off on the next fill cycle. Requires installing a new water valve.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker is not working. I had to shut the water off to the fridge becasue the water kept running from the icemaker inside my freezer. Any idea what may be wrong?
A small white tube normally connects from the hard pipe entering the freezer compartment and directs water into the icemaker tray. This tube often comes off and allows water to run down the back wall of the freezer. If this is what is happening, take the tube to the kitchen sink and warm the end of it with hot water, as hot as you can stand. Slip it back on the pipe end quickly and as far as you can without making it too short to reach the icemaker fill area. The warming and reattaching process has worked for me several times and I have had no repeat problems using this technique. I suspect the factory assembly was done hastily and the tube was not fully in place.
Oct 08, 2009 | GE GTH22SHS Stainless Steel Top Freezer...
Ice cube tray isn`t filling with water but I have water on the door dispenser.
Hi, Check the inlet tube that comes through the back wall into the ice maker. See it has froze shut.
If there is ice in the tube, thaw it out and let the ice maker cycle. Plan on changing the inlet valve if the tube is plugged.
If the inlet is not plugged, let the ice maker cycle and listen for or test the valve for 120V. If there is a buzzing sound or you are getting voltage and no water, remove the tube frrom the valve that leads to the ice maker and see if water comes out of the valve.
If no water comes out of the valve, change it.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Freezers
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
161 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
