Question about Uniden BCD396T 6000-Channels Handheld CB Radio
Get gets stuck on 3 and 5
My scanner will scan but its like it gets stuck on 3 and 5 how can i fix that
  • 36 Answers
Probably picking up an open mic like a baby monitor or something like that, you may have to lock out those channels or re- program them.
Posted on May 25, 2009
Scanner stuck on one channel and won't allow me to enter new freq
Push the "L/O" lockout button and it will lockout that channel.
When you press "Scan" you have to have at least one of the banks scanning, so press 1, 2, 3,....9, 0 whatever bank you have channels programmed in order to automatically scan. You should be able to press "Manual" to see each channel individually.
May 07, 2014 | Uniden Bearcat BC 220XLT Radio Scanner
I need to delete one frequency at a time from a uniden BCD996T scanner.
it scan run all nuber threw all exct there 3 numbers wont scan it like there stuck they wont move at all then weather radio come on and it turend off
t
Feb 24, 2014 | Uniden BCD996T Base Scanner
Stuck at 80%
try the new version of driver
Jun 26, 2013 | Xerox DocuMate 152 Pass-Through Scanner
My Epson scanner makes whirring noise
There are a couple possibilities that can cause the problem.
1. you need to unlock the scanner. There is a lock at the side of the scanner that could be in the locked position which is preventing the scanner from moving. you can use a nickel or penny or screwdriver to turn it to release it.
2. the tab that is holding the gear is broken
3. the glass is not attached 100% to the upper case and the scanner is hitting it when trying to scan.
if its 2 or 3, you might be better off getting a replacement.
thank you
May 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Can't scan scanner gets stuck
Hi, you just reinstall the scanner software and then try.
OR
If your scanner in the warranty then replace it because this is the major problem in the flatbed scanner.
May 24, 2009 | HP Scanjet 4470c Flatbed Scanner
HP PCS 2510 Scanner module keeps running
Please follow my steps:
1. Make a ring, which is 5mm high and 1/3 cut so that it can be mounted at the far right end of the rail bar where the scanner module sliding back and forth. This can help get the none-stopping scanner out of the trap!
2. Do the Semi-Reset opreation. Then you can see the healing result!
Dec 22, 2008 | HP PSC 2510 All-In-One InkJet Printer
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Canoscan 4200f clicking noise when turned on
Cool. I bought the scanner 2-3 years ago and i had the same problem. I gave it back, received a new one ... exactly the same noise ... on 3 different computers. **** product!
Jul 30, 2008 | Canon CanoScan 4200F Flatbed Scanner
Scanner gets stuck
its a known problem. check usb conection. switch usb port, dont go through hub.
Feb 22, 2006 | Mustek BearPaw 1200CU Plus
Uniden BCD396T 6000-Channels Handheld CB Radio Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
