Lamp, timer and standby light flash on remote.
Tv turns on then shuts off
  • Sonny Berry
    Sonny Berry May 11, 2010
    Whats the model number of your set. Please respond to this same post with the model number and I can assist you with the possible cause.
SOURCE: The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
you must change ic reg.(ic mcz 3001db)
Posted on May 06, 2009
Slinteriors
  • 8617 Answers
SOURCE: Standby/temp light and Lamp light are flashing
Sounds like a samsung but I will need the model number to assist you more accurately. Please respond to this same post.
Posted on Dec 04, 2009
alpug
  • 1961 Answers
SOURCE: installed new lamp ..tv turns on then shuts off
did you replace the all three lamp the red,green and blue lamp?if not what color of lamp did you replace?try to dis connect the lamp that you installed then power the tv again if it work there might be a problem on your compatibility of lamp u use..or you can replace the convergeance ic there are two big ic in there sometimes labelled STK replace them...hope this could help..good luck!!
Posted on May 21, 2010
  • 8457 Answers
SOURCE: My Samsung HLS4666WX TV has started shutting
The lamp in the tv been in use about 1 1/2 or 2 years,the tv on about 4 or 5 hours a day?The lamp life span is over.Replaced the lamp.
Posted on May 31, 2010
taran_2005
  • 10515 Answers
SOURCE: Samsung HLS4266 DLP tv.
In all likelihood then the ballast is failing, this is very easy to replace just a little board attached to the lamp by a couple of wires, just when you remove lower bottom have a look at the lamp wires and you wont go far wrong it's available here
http://www.partstore.com/Part/Samsung/Samsung/BP4700037A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLS4266WX
The part is in that link highlighted in my last post just click on it and it will take you to the supplier, if you cant fit it yourself a technician shouldnt charge more than $100 for the housecall and fitting unfortunately there are a lot that want $150 just to turn up so if you could get someone whos practical this is very easy to do.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 07, 2011
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
Standby lamp flashes
if the lamp light is flashing,remove the lamp and check it there is 98% of possibility that is bad.
May 19, 2009 | Initial HDTV-320 32 in. LCD TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
