Question about ASUS A8Jm Notebook
Battery i have a asus a8j laptop. now the problem is whenever i try to put the laptop charger it would automatically turn off and it will just reboot and reboot.
  • bjranola May 24, 2009
    thanks man.
2 Suggested Answers
  • 17 Answers
SOURCE: Disassembly guide for an ASUS A8J
Here is the disassembly guide for the ASUS A8J:
http://www.mediafire.com/?9utgx3g2gvy
Posted on Apr 13, 2010
Asus laptop restarts when charger is connected
You can try doing a hard reboot to see if its a small glitch by shutting down the laptop, unplug it, take the battery out. Then with the battery out and unplugged hold the power button down for 30 seconds then release. Then put the battery back in, plug the laptop back in and boot it back up to see if the issue persists.
Mar 18, 2016 | ASUS Computers & Internet
How to turn back on my touch screen ASUS VivoBook S200E .that's been about a week now it just stopped working I tried everything people said and suggested ....Help please
First thing to try is a hard reset
1. turn off laptop
2. remove charger
3. remove battery
4. hold the power button for at least 30 seconds
5 put charger and battery back in
If this does not work then we would suggest saving the data and do a windows restore. We can provide steps if needed.
Dec 26, 2014 | ASUS Computers & Internet
HOW TO TAKE APART THE ASUS A8JS LAPTOP
This will show you how to open the laptop
hope that was helpful
Jul 15, 2014 | Computers & Internet
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
Hello. Today in the morning my laptop (Asus A8Jseries) was working alright. Then after 6 hours when i tried to turn it on, it didn't. I mean, it starts to work and Asus symbol comes alone, but then it just...
If it happens only when you move the adapter plug inside the power jack, it's likely that you have a problem with the power jack inside the laptop. The power jack has to be resoldered or replaced.
If it happens even without touching the adapter plug, the problem could be related to the faulty power adapter.
You can test the power adapter with a voltmeter and find out if the ouputed voltage is correct. If the voltage is not correct, replace the adapter.
http://www.chargerbuy.com/replacement-asus-a8-ac-adapter-19v-3-42a.html
But don't trust that even if the output votage matches specifications. It's possible that the power adapter doesnt' work correctly under load. Test your laptop with another known good adapter. If the laptop works fine with another adapter, your power adapter is defective and has to be replaced.
Mar 13, 2011 | ASUS A8J Laptop AC Power Adapter (4.3A...
When I start up the computer it only goes to the Asus black screen and no farther. I put in the recovery disc but nothing happens. I can get into bios but not sure what to do once I get there. Help
Remove your battery completely, plug the AC cord in and try a reboot ;)
(If you leave your battery charger plugged in on a fully charged battery it may cause a voltage issue preventing your Graphics card or other things to start.)
Aug 26, 2010 | ASUS X83Vm-X1 Notebook
I need an A8J camera cable. A8JS-4s034P
Not sure what you are after, the webcam is built in this model laptop (A8JS-4s034P)
Jul 29, 2010 | ASUS Eee PC 900 Notebook
I tried disassemble the heat sink area for ASUS and then when i put back the heat sink area, the LCD would not work.
Hi, you will need to double check the position of the heat sink, also you must ensure there is sufficient gel between heat sink and cpu, this is quite cheep to purchase.
Hope this helps
Jul 24, 2010 | ASUS A8Js Notebook
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
ASUS A8Jm Notebook Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
