Question about Durabrand DWT1905 TV
Uverse remote connection
The code att uverse has for remote programming does not work is there another code for the uverse remote for durabrand 13 inch television?
    Champion:
  • 217 Answers
Hi! i have here a couple of codes for your tv you could try them hope it would help 0189 0135 0157 0153 0254 0458 0217 goodluck!!
Posted on Jun 03, 2010
  • 30 Answers
Durabrand Television 1259
Posted on Sep 20, 2009
    Problem Solver:
  • 12 Answers
This process should be used if the code for the device is not listed in the Manufacturer Code List.
  1. Turn on the device you wish to program.
  2. Point the remote control at the device.
  3. Press and hold the Mode key (TV, DVD or AUX) you want to program. Without releasing the selected Mode key, press and hold the OK key simultaneously
  4. Release both the Mode key and the OK key at the same time.
    All the Mode keys will flash twice indicating programming mode.
  5. Enter code 922 by pressing the number keys on the remote control. The selected Mode key will flash twice indicating correct entry.
    Note: This next step is For AUX Searching only, press and release the PLAY key then press:
    • 1 for VCR
    • 2 for Receiver/Tuner
    • 3 for Amplifier
    • 4 for Home Theater In The Box (HTIB)
    All the Mode keys will flash twice indicating correct entry.
  6. For AUX only, press and hold the PLAY key and wait until the device turns off, then release the PLAY key.
    • The REW key can be utilized to go back through the codes one at a time.
    • The FF key can be utilized to move forward through to codes one at a time.
    • Press the PLAY key to resume auto search of device codes.
  7. To save the code, press the ENTER key on the remote control (bottom right) or press the EXIT key to return to normal operation.
    The selected Mode key will flash three times and return to normal operation.
  8. If no valid code is found, the red light will flash two times and the remote control will return to normal operation.
  9. Turn the device back on using the remote control. If this doesn’t work start over or try Manual
  10. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the AT&T U-verse TV Receiver, press the AT&T Mode key.
Posted on Sep 12, 2009
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
Need att uverse remote codes and Durabrand hb2404d tv codes to set up tv?
0185,0188,0184,0183,0180. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 18, 2014 | Durabrand Televison & Video
Trying to program Uverse remote for Emerson 32 flat screen
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Jul 04, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Att uverse tv remote code for a Dynex TV?
hi! i have a couple of codes for your dynex TV, you cuold try them 0189 0135 0157 0153 0254 0458 0217 hope it would help! goodluck!!!!
Dec 26, 2009 | Durabrand DWT1304 13" TV
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
I need ATT uverse remote control code for Onkyo AV rec TXSR304
hi just a tip! try to program your remote to control both your tv and the cable box both at the same time so when you try to adjust the volume automatically both tv and the cable box will respond. you can actually call uverse for that so that they can assist you on programming your remote to your tv and cable box. hope this would help goodluck!!!
Jan 04, 2009 | Durabrand DWT1304 13" TV
Need remote control code for ATT U-verse
Use the code search method. MANY TV's are branded from a few suppliers. Emerson has about 50 codes!
Mar 02, 2008 | Durabrand DWT1304 13" TV
Durabrand DWT1905 TV Logo
528 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
