Bunn has recalled certain brewers made between certain dates. The B10 is one of them. The recall affects roughly 1.5 million brewers, so it might be worth looking at their recall page.Bunn has recalled certain brewers made between certain dates. The B10 is one of them. The recall affects roughly 1.5 million brewers, so it might be worth looking at their recall page.
Same. The reservoir leaks because the seal around the drain has deteriorated.Same. The reservoir leaks because the seal around the drain has deteriorated.
AnonymousMar 16, 2014
does not heat the waterdoes not heat the water
You can't post conmments that contain an email address.
You can send me your thermostat or I will send you my reservoir. There is no sense in throwing out 2 otherwise good coffee makers and Bunn will NOT supply replacement parts.
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
Hello. I would say that you are going to have to call: For repair information, call 800-352-286. They don't usually supply commercial repair houses with part information, or you could try here:
Hi Tina - I'm no expert on melted butter in your coffee maker; but, I'd bet that the butter also got into the internal water tank where the water gets heated. Try going to the Bunn website: www.bunn.com , and click on their Customer Service link. You can either call their toll-free number or write to them with your problem from there.
THis sound is usually caused by the water being low in the tank. This can be because the machine is left on for long periods without being used. If this is not the case, then it would probably be your heating element getting small holes in it.
leaks water
